Returnformer
- Joined
- Apr 11, 2019
- Messages
- 90
They restocked sooner than expected, so I went with the ebikeling 48v 1500 watt waterproof kit in the end. also got the headlight/horn kit. horn is good but the light is a bit meh. they said its 1000 lumens, but im also a flashlight buff, and it doesnt seem close. maybe defective? at least i dont have to strap it to my helmet, though.
battery is a 52v 17 ah super shark from em3ev. i went for the higher ah cells, but looking back, theyre not rated for as high continuous amp output, and the controller is 35 amp, so i probably shouldve gone with the lower ah higher amp rated cells, but oh well. hopefully it wont catch fire, just the battery's overall life wont last as long. its rare that i ride more than 15 min at once tho. one question remains regarding this combo, tho. im guessing a 52v battery has a slightly higher min voltage that you should drain it to than a 48v battery. since the kit is intended for a 48v battery, will it drain the 52v battery too much, further reducing life expectancy? or are they close enough that it shouldnt matter?
only had one small ride so far, but performance is what i had hoped. ive gotten up to 33 mph according to the speedometer, which is probably overstated, but ill check that with waze another time. should be at least 30, though, which is exactly what i wanted. I've got a couple more minor mods to make, such as changing to a 203 rotor in the front, but im still waiting on it to come. its basically done, though, and overall im quite pleased with how it turned out so far.
on my previous build i covered the controller and connections with plastic to protect them from the elements. still debating whether to do that on this one...
