lazarus2405 said:
Why the Milwaukee over the DeWalt? I thought that a123s were the dog's bollocks and Emoli second-best.
That depends on how you weigh the relative importance of capacity and ease-of-charging versus cell life and high C rating (the drainrate). In real-world ebike conditions, emoli cells are each about 3.8v nominal and 2.6ah, whereas each A123 is about 3.2v nominal and 2.2ah. That difference adds up, and because the cells are both the same size, emoli packs can be made more compact. Emoli cells can be charged with unmodified RC or other common chargers for lithium cobalt cells. There's still few good charging options for A123's, but that will change soon. The A123's should live much longer though -- from the best info available, it sounds like about twice the cycle and calendar life of emoli's. However, both types live an exceptionally long life for a rechargeable battery (1000 deep cycles for the emoli versus 2000 for the A123...about).
Emoli's can be discharged continuously at 12C, the A123's at 30C. For an ebike sized pack, the difference matters little since a 10ah emoli pack can put out 120 amps -- far higher than any controller's current limit or ebike motor's ability to use those amps. In the RC world though, the little airplanes regularly pull 30C from a 1p A123 pack, so A123's are much preferred for powering that hobby.
The emoli's have been well tested and highly praised by Jondoh here, and Ypedal uses the same chemistry in a different brand and form. The A123's have likewise been well tested and received high praise. Myself and a couple others have argued that emoli's are being generally overlooked without good reason. Both cells have been very widely reviewed in the battery section of http://www.rcgroups.com.
And with the Milwaukee, one pack contains 7 cells with a nominal voltage of 4v, and approx. 3Ah per cell. With $500, that's 6 packs, 42 cells, for 540Wh. How much current can those Emoli discharge continuously? Because if they can handle a lot, I think that a 84V 6Ah 21s2p setup would be optimal as a starting point. I can always add more as future funds allow.
I agree with your 21s2p set up, which should provide 72 amps continuous without overheating or suffering damage -- good headroom for a 40 amp controller. You should read Jondoh's emoli pack build:
http://endless-sphere.com/forums/viewtopic.php?t=233&highlight=milwaukee
He runs 2, 7-cell packs in series. You might need to bypass the internal BMS (battery management system), or pull the cells out of the container completely if you want to put three of these packs in series because the BMS might not like that much voltage, although it does fine with two packs in series. The same thing has to be done with Dewalt/A123 packs, and isn't that difficult for someone who has some basic experience with electronics and soldering.
Amazon shows a shipping weight of 2.4lbs for one battery pack. That'd be ~10lbs after it is all packaged, providing 540Wh. For the same $500, I could make a 92v 8s 20Ah 1840Wh pack, weighing in at 112lbs. 1/3rd the capacity, at 1/11th the weight.
You mean by buying $500 of SLA instead? 112lbs...ha ha! Not feasible on a bicycle unless pulled in a trailer.
How much abuse could such a setup take in terms of deep discharges, and how quickly can they be recharged? And how on earth would I go about modifying the things into a setup like this properly? I assume all that extra little protection circuitry in the pack need to be preserved somehow. If you can explain to me how to take those packs and turn them into an easily-chargeable safe single battery pack, I'm all on board.
Lithium powertool batteries are made to handle deep discharges and lots of general electrical abuse. Myself and many others here can explain exactly how to build a pack with either one, but a lot of depends on some build preferences and specifics only you can answer. I would recommend doing some more reading here starting with Jondoh's build for emoli/whole pack systems, then going to GGoodrum's thread about A123 pack builds here:
http://endless-sphere.com/forums/viewtopic.php?t=2498
Then come back with any questions/concerns you still have.
