The new battery showed full charge on LCD display but would not run motor. Connecting voltmeter across positive and negative of controller input,(battery output) meter could not settle on a voltage OL...... ) before BMS read 54.1 volts. . Decided to change it but the new one had no switch connection. 1st question: Is it possible to install a switch by breaking the B+ line to the 13s header? Back to story: I plugged in the header (because it was easiest) and proceeded to solder other connections. The P- connection had a small spark when I connected it. Now with new BMS I have 41 volts @ output of battery, 54.1 between B+ and B-. Did I blow up the new BMS by connecting 13s header first? I started checking install instructions on the internet and it seemed they wanted connections made in a certain order.
