methods said:
Oh, I forgot that I ordered these.
Sensorless boards!
I have not been following up on the threads.
Wasn't there something about a max frequency on these that was causing people to have to only run up to 70% throttle or something?
I recall something about hooking to a pin in the controller?
Anyhow, personally think sensorless sucks (but Patrick... tell us how you really feel... lol)
I know you characters love this stuff so let me know who wants one and I will ship them out.
I know that Luke gets one and Gary gets one.
Who else?
-methods
hi
I did not find the fault with the sensorless boards it was observed while I was off the road. what I did do when I finally got a sensorless board to check out was to find the find the point of the fault , the reason is still beyond me as simmilar to you methods I don't like the sensorless fix, here were my results.
I was using a 12 fet controller fitted with a sensorless board and a puma motor(later confirmed with a kollmorgon)
I started at 48v
I observed that when the throttle went past approx. 75% the motor started to do strange things ( jumping and stuttering it was setup on a bench)
thinking this might be voltage I changed to 36v
the same results were observed whenthe throttle got to 75% so it cannot be the voltage
to prouve my theory I changed to 72v same results as before.
I disabled the sensorless board left it in place and started doing other tests.
I was going through the pads first testing for a voltage then if there was none shorting to ground to see what the results would be, I found a few 5v pads that LEDs probably connect to but that is for another time, I finally came on one marked SLA i connected this to ground and found this was a fixed throttle limitter, with all the advanced features of this controller that seems strange why do it, software would be so much better.
then I had a thought the speed mesured was about the same as the speed at which the sensorless went wrong so i enabled the sensorless board with SLA grounded and gunned the throttle, not a glitch in sight the motor ran as smooth as silk.
I think that SLA must stand for SensorLess Adaptor
Now I was testing with geared motors much higher reving than direct drive, I thought it could be the rpm of the motor that was the problem but I was able to get much higher smooth revs running at 72 v than at 36v but the problem was always at approx 75% throttle if you mesure the throttle signel I thing you will find that it is about 3v.
I only just got a DD motor and it came in a rim it will not fit in my bench test unit so I can't test DD but I fear that may not work either, i hope I am wrong.
Geoff
