Omegalpha
I tested a new front hub motor with new controller and display was working and the throttle was working and made the wheel turn. Then a few hours later I wanted to test again and the LCD display would not turn on. Would a short in the throttle connection cause the controller to fail? The throttle I had had a connector that didn’t fit so I stripped the wires.
I tested with a multimeter and there is a voltage on the red and black wires to the LCD display. I bought a new display as well but it doesn’t seem to turn on either. Display doesn’t turn on and The throttle doesn’t work.
It seems like the controller has a problem, but it is new and I just got it. Could some kind of short cause the controller to fail? Hoping someone could help me fix this problem.
Here is a picture of the LCD Connection.
