Somebody should make a parasitically powered Bluetooth temperature transmitter. It could be powered by the 5v hall line or directly from phase wires with the right regulator circuit.
teslanv said:Nep,
Per previous notes you have the Kv at 13.16 ...
neptronix said:I definitely prefer this motor over an mxus 3kw for now though.
When you spin the motor by hand, you cannot feel any cogging
Here's the raw dyno data from the first post run against a couple of standard Load Line plots identical to those used in the ebikes.ca simulator. The motor data shown here is the identical data from the original dyno plots - just plotted vs speed instead of torque to yield a more familiar 'justin simulator' presentation. A 'waste heat' plot is added (simply Pin-Pout).neptronix said:Remember that i am running 120% mode on my controller to get that top speed. On 100%, the flat speed is more like 38-39.
As always - sort of depends on what you are going after. In this example from a top speed perspective a smaller wheel appears slightly counterproductive, although it would certainly add some acceleration at the low end. By the estimate below for a 24 in wheel, it didn't help WOT speed even on a 7% grade...speedmd said:Looks like this motor would benefit from a slightly smaller wheel /FOC.
Hmmm - missed that - thanks for pointing that out. Although that is for 'achievable' top speed not 'equal' speed. To get a true 'speed-based' comparison, we would need to throttle back the 26" wheel case to less than WOT to reduce the speed to the 24" wheel case - a little beyond the scope of these simple no-calculation plots...speedmd said:It does look to reduce the waste heat significantly on the flats. Down to aprox. 200W from 300W. Battery power looks to be a big difference also. Interesting trade off.
