Got my kit. Seems to have 3 mounting plates instead of 2 ( one extra included? )
I did get a power connector.
Yes, the power connector is not keyed at all, i don't like this design choice.
On the other hand, the battery cable must bend sharply to the left once the connector cover is put on, so the wire will naturally bend in the direction and create an indicator of which way it should be inserted so this is OK.
The motor appears to contain a freewheel inside and the drag seems low enough when not engaged that you would barely notice it while pedaling with the motor off. Turning the drive sprocket in the other direction produces a lot of resistance ( as expected ), but that resistance is even.
And goddamn is it light!
