comand
A couple of months ago, I bought my wife a Raleigh Detour iE to allow her to commute to work
without having to worry about parking. So far, it's been working great -- so great that I now want
to escape the terrible traffic of my commute as well. However, I would prefer to build a kit into
a bike that I want to ride, rather than spending $$$ on a pre-built bike.
Desired max speed on level ground. mph or kph: 30mph -- enough to keep up with traffic.
Desired max range at what cruising speed. mph or kph: 20mi with 25-30mph cruising speed.
Preferred bike wheel size, or wheel size of bike you want to convert: 26"
Brake type of motor wheel. Disc or not: Disc
Rider weight: 195lbs
Terrain: Mostly flat, some hills with 10-12% grade.
Budget: $1500
My commute is 10mi each way, downhill on the way out, uphill on the way back,
mostly flat in the middle (I'd say 30% descending/climbing, 70% flat). All
pavement, all the way. I don't mind pedaling, I just want to ride to and from
work in normal clothes and not sweat my ass off.
I think with the sort of climbing I'll be doing on my commute that a geared
hub motor in a 26" wheel would provide sufficient torque for climbing (without
resorting to a mid drive). I don't want any resistance when coasting downhill
and want to be able to ride at slow speeds with my kids on the weekend with no
assist, so am steering away from direct drive hubs.
I'm not having much luck in finding a decent mountain bike (new or used) with
the right frame size for me (L/20") that has decent components (hydraulic
brakes for instance) and 26" wheels. I was thinking about buying a bike with
27.5/650b disc wheels and just replacing the rear with a 26" hub wheel
(76'er), transferring the brake disc to the hub wheel.
I am looking at most MTB hardtail bikes, like the Specialized Pitch 650b, or a
KHS SixFifty 200. Something in the ~$400-500 range, although I would love to
spend less to get something used (CL in my area hasn't been fruitful lately for
anything except the $2000+ range).
I am strongly considering the kit from gocarlite, which is advertised as
48V/1300W peak, with the PAS add-on ($620).
http://gocarlite.com/product/high-end-geared-motor-kit/
I would pair this kit with a 48V/20ah battery from lunacycle ($460):
http://lunacycle.com/batteries/packs/48v-samsung-18650-20ah-ebike-battery/
If anyone can recommend a better kit for my purposes, or a better battery, or
a better bike setup, please do!
Budget: $1500
