rocketman58
- Joined
- Aug 6, 2022
- Messages
- 41
I was able to resolve one problem thanks to answers I received on another post. However, I still have three issues, one new and two I have not been able to correct.
New issue: The battery usage bar is not displaying correctly. Yesterday it was displaying 50% battery left, but is now showing 100% left. The display is showing voltage at 44.2v on a 48v system. Actual battery has about 50% capacity left.
Old issue 1: I have never been able to get throttle to work
Old issue 2: I have never been able to get the brake cutoff to work
How do I determine if I have a controller problem, a display problem, or if perhaps the 1-4 wire is faulty?
- P5 setting is 0 (default)
Setting P5 to 15 for 48v makes no difference in display, not does any other setting.
Prior to changing P1 and P2 settings, display was showing 50% battery capacity left. After setting P1 and P2 back to previous setting, battery display did not change
- No combination of settings for throttle works
Throttle indication on display does not show when throttle lever is pressed
Seems like signal is not getting to the display or controller
Triple checked all connectors, and all were tight
Throttle has a male connector, and so does the 4-1 wire it plugs into. Using a female to female extension wire to complete the connection
- Brake indication on display does not show when the brakes are applied
The brake levers have a female connector, and so does the 4-1 wire they plug into. I am using a male to male extension wire to complete the connection
