Mark_A_W
It'd really sing with 60v and 30 amps.
kfong said:After a year of work and I get this BS going on. The motor has less than 50miles on it and wasn’t even pushed that hard. Before I take it apart does anyone know what what’s going on after seeing the video? You can here the motor spin but there isn’t any connection to the wheel. I really like this setup in the trails, but if the motor isn’t reliable I would not recommend it. I want this to work, it a lot of fun and fairly quiet as well. Motor was never really hot and the trails should not have stressed out the motor. Working voltage is only 40volts. This should not have even been a problem.
deecanio said:what controller is it?
I had a similair problem with my puma and turned out to be the keyswitch on the controller was in the wrong position?
long shot but might help, that was on a c-lyte controller.
D
Mark_A_W said:The motor is running backwards.
GrayKard said:kfong said:After a year of work and I get this BS going on. The motor has less than 50miles on it and wasn’t even pushed that hard. Before I take it apart does anyone know what what’s going on after seeing the video? You can here the motor spin but there isn’t any connection to the wheel. I really like this setup in the trails, but if the motor isn’t reliable I would not recommend it. I want this to work, it a lot of fun and fairly quiet as well. Motor was never really hot and the trails should not have stressed out the motor. Working voltage is only 40volts. This should not have even been a problem.
What video?
I have read that the BMC clutch is the weak point on the motor but don't know if that is what is going on with yours.
Gary
kfong said:Mark_A_W said:The motor is running backwards.
Nope, you can hear it spin but no turning of the wheel.
Kfong, have you changed or move the hall wire recently, etc...If you hall signal is miss matching you will get similar effect. But sound more like a clutch problem. Here is the video link that show you how to replace the BMC clutch assemblykfong said:After a year of work and I get this BS going on. The motor has less than 50miles on it and wasn’t even pushed that hard. Before I take it apart does anyone know what what’s going on after seeing the video? You can here the motor spin but there isn’t any connection to the wheel. I really like this setup in the trails, but if the motor isn’t reliable I would not recommend it. I want this to work, it a lot of fun and fairly quiet as well. Motor was never really hot and the trails should not have stressed out the motor. Working voltage is only 40volts. This should not have even been a problem.
http://www.youtube.com/watch?v=OYbY98cH1_8
Mark, why do you said the motor is running backwards? I was wondering if I missed something in the video? There is only one way to mount the motor, since one side is screw-on freewheel, other side is disc mount, you cannot possible mount the backwards.Mark_A_W said:The motor is running backwards.
itselectric said:Mark, why do you said the motor is running backwards? I was wondering if I missed something in the video? There is only one way to mount the motor, since one side is screw-on freewheel, other side is disc mount, you cannot possible mount the backwards.Mark_A_W said:The motor is running backwards.
Mark_A_W said:kfong said:Mark_A_W said:The motor is running backwards.
This is exactly what happens when you run the motor backwards.
In my experience, the clutch fails "on", rather than "off".
itselectric said:Kfong, have you changed or move the hall wire recently, etc...If you hall signal is miss matching you will get similar effect. But sound more like a clutch problem. Here is the video link that show you how to replace the BMC clutch assemblykfong said:After a year of work and I get this BS going on. The motor has less than 50miles on it and wasn’t even pushed that hard. Before I take it apart does anyone know what what’s going on after seeing the video? You can here the motor spin but there isn’t any connection to the wheel. I really like this setup in the trails, but if the motor isn’t reliable I would not recommend it. I want this to work, it a lot of fun and fairly quiet as well. Motor was never really hot and the trails should not have stressed out the motor. Working voltage is only 40volts. This should not have even been a problem.
http://www.youtube.com/watch?v=Jg4zOmHTdW4
ebikes-sf said:I noticed that BMC gear replacement video uses old V1 motor which doesn't have o-ring holding gears in place. Here are pics demonstrating the extra step needed for V2/3.
http://ebikessf.com/disassembled-bmc-motor
Vince, just send me your blown clutch and I'll replace it with V3 clutch that is made of stronger grade steel; I haven't seen one fail yet.
ilia
full-throttle said:kfong,
was there a little key between the axle and the freewheel?
