winkinatcha
Ahh Amberwolf,
The sledge hammer, King of the E-bike Tools Fixes most anything
Joe
Joe
amberwolf wrote:
I, too, suffer from the wanderings of tools as they seek shelter from my abuse.
Not a day goes by where I must carefully stalk them in their lairs so I might fix something, and often must use whichever tool I manage to actually catch to do the job of another that has escaped my clutches.
Generally the sledgehammer is easiest to catch, as it is too heavy to run very fast.
I read someplace that it does shift under load. That, plus it only takes about 1/3 turn from lowest ratio to highest ratio as opposed to two full turns for the N171B.Would you find out if the 360 can be shifted under load?
that''d be one heck of a velomobile lolThe fingers said:At first, before I read the caption, I thought it was a cutaway view of a very large velomobile! :lol:
...and shipped todayddk said:ordered stuff from MFG Supply
sprockets will need sum grine--denz
shooulda bought the v-8Rassy said:I read someplace that it does shift under load. That, plus it only takes about 1/3 turn from lowest ratio to highest ratio as opposed to two full turns for the N171B.Would you find out if the 360 can be shifted under load?
Do a search on N360 and you will find a number of forum members using it. They could probably answer this type of question based on actual experience. Apparently Fallbrook has also made an autoshift version but information and availability is still hiding.
Everything is relative though. If you read some of LI-ghtcycle's posts he was very happy with the N171B manual shift on a two wheel recumbent.
And my auto shift N171B does shift under power, both up shifts and down shifts. That is the main reason I like the 4 turn auto shift developers kit versus the 2 turn manual NuVinci.
Wait a minute! I already have a complete manual shift N171B on the shelf that I don't ever intend to use because of my preference for the auto shift.-new plan includes nuvinci one last time before I give it to Rassy
hope Li-ghtcycle is just bizzy!Rassy said:...Anyway, I'll hang on to mine for a while just in case you end up really likeing yours and need a part or something.
Plan B for mine is to see if internal parts from the manual shift can be used for replacement parts for the auto shift one that started making noise.
