no frustrations today!
Armed with a grinder nothing gets in my way...
Found this on the ground.
Haven't even sat on the trike and this bolt snapped off.
Betrays the quality of components that makes up the front fork
First off the legendary "built-in-workstand" put into play
removing an axle from a trike simply involves removing the wheels and loosening the setscrews on whatever devices are mounted. Don't forget to remove the keystock. (one per)
Takes a couple of minutes, with the help of a rubber mallet. or a hammer and a chunk of soft wood set against the threaded axle end. I prefer the rubber mallet but I've used the other method.
Before I can mount the sprocket and disc brake I need to make shims to fit the 5/8" hole in the mini-hubs to the 15mm axle. I'm using a brass tube for this.
After making the initial cuts with the 4 1/2" cutting wheel mounted on the angle grinder I start to really measure and shape the shims using my
zuper-low-powered-toy-that-resembles-a-miniature-Dremel
Patience Is a requirement but if my hand slips (and it does several times) the force of the motor is so low I don't cause any damage to the workpiece or more importantly, me.
Some people like to use files; I don't.
All shaped up and fitted.
A tube doesn't belong here so until Tuesday it's like, gone man. (the 44-tooth sprocket doesn't clear this axle support tube - no problem *reaches for the angle grinder with the cutting wheel still attached* )
All fits with room to drop in the hub keys.
After I broke the wrong link on the chain I figured it was time to clean up and ride, so that's what I did.
