RustyKipper
It's coming along albeit slowly. Its took 3 weeks of chasing BMS battery to get them to even send the new CST motor and controller. Unfortunately due to the poor packaging the motor wiring has been damaged, luckily the conductors seem ok even though the red and yellow wires are showing, I need to re-heat shrink them somehow.
I laced the motor into the rim yesterday and looks to be running nice and true. I couldn't get the controller to work, it seems without a display I have to link some of the wires that normally go to the display, I think 36V to lock and Rx to Tx, so might try this tonight. Then I just need to save up for some bigger Ah batteries, planning on 12 x 15Ah headway cells, I've bought one to see the size so am working out a battery enclosure. I could maybe reduce the shunt so that I can run the motor from my current 9Ah battery but wouldn't really gain much.
Planning ok keeping the front 250W motor for use around town / shared cycle ways ect but can use the rear 500W as well for the dreaded hills. The 250W motor stopped working on the way into work last week, I had to use the granny ring and pedal HARD, I managed 6 mph where I would normally do 10mph with the motor, it felt like pedalling with the brakes on! Very sweaty when I got to work, still did 30mph+ downhill! Turned out that the constant pounding of potholes fractured one of the pedal sensor wires.
I am however quite apprehensive about having 2 motors, if and when I get stopped by the boys in blue I need to do some serious blagging, like the rear motor is a regen brake, or maybe just have the rear 500W motor and re-label it 250W. I'm trying to keep the bike as stealthy as possible with some big rotors masking the motors but think my speed might give me away, I have done 40+ down one of the 20% descents before now without any motor assistance!
