How much flex does that fork have with your repaired cross brace/brake booster?
It is kind of ridged. I used JB weld first then got carried away with the Fiber fix tape. Them put several layers of fiberglass resin over several layers of the Fiber fix tape. I really do not see it breaking or failing structurally. I just needed about 1/2" to clear the fork on the right side facing the forks or left side when sitting on the bike.
The reason the wheel is not centered was not the unorthodox repair job but the short axle on the Bafang motor. I could only get one torque arm on it and used two nuts on the opposite side where the wires come out. The wheel does not move when I push on the sides at the top of the wheel so the axle is secure and snug.
I just hope that the bike shop will hook up the cable. They might not due to liability. If they sell me the cable and the cutting tool the guy down stairs can probably do it.
There is another post here about 3D printers. I will be looking at that. Not sure about converting the Currie now though. If the motor mount holds up over time I may have finally build a reliable rear chain drive. Since the 26" dual suspension has the Bafang up front I do not need a belt drive there either but the silver 27.5" Dimond Back could use an RC motor with a belt drive front and rear if possible. I would not be using 1-1/2" pressure treated wood but quality 3D printed brackets.
I am not sure yet though as still need to build the Haro V3 as well as some custom battery packs with the LIFEPO4 cells. In fact maybe with a 3D printer I can print cell holders for the K2 Energy LFP26650 cells. The wood corner moulding worked out perfect for the 18650 cells abd built three 1S - 6P packs so far and should probably finish that for a 13S - 6P pack I can parallel to the factory built 13S - 7P pack that seems to lack discharge power. My guess is it is only putting out 600 watts.
I remember running the 1,000W hub motor with the same controller with 12S LiPo and getting about 28 mph out of it. Now I only get about 22 mph. The 1,800W brushless motor is geared for about 35 mph at 53V but is only doing about 23 mph also. The only big difference is the acceleration. The 1,800W brushless motor gets up to 23 mph much quicker and has about twice the power up hills. I really can not seem to explain that. Actually I did not see much difference in top speed between my 10S Lithium packs and the 13S pack.
I have a lot of experimenting to do and testing. It is my main purpose for this post. To shoot videos pertaining to the function and performance of various e bike motors and controllers and battery combinations. I have a top speed and gear ratio calculator provided by electric scooter parts. I will need a custom 90T sprocket for the 3 kilowatt brushless motor.
The LIFEPO4 pack charges to 3.7V per cell right ?????
3.7 * 16 = 59.2V. I do not believe there will be a lot of voltage SAG with a 16S - 5P pack as the K2 energy cells are decent capacity right ? 3.8 Ah * 5 = 19 Ah. With the right BMS will that be a 3,000W battery ? 16S - 5P.
58V WITH SAG.
I do not know the total kilowatts possible from the 16S - 5P pack though. I know that a minimum of 2 kilowatts to the wheel is required for 40 mph right ?
Please let me know.
Thanks.
LC. out.
