You could inspire posters if you didn’t blow off suggestions. Seriously, you waste money on half assed builds.
There is nothing wrong with having high standards. Can you post some of your builds ?
Most of my builds may be considered half assed but not all of them.
Building e bikes is more than just transportation for me it is my only hobby currently. If I were to average out how much I spend it would be about 100 bucks a month or less.
Many folks spend that in a week on lottery tickets or a casino with nothing to show for that money or do expensive recreational drugs which could cost that much in just a few hours so what seems like a waste to you is therapeutic for me.
One good extremely expensive build can still break down if it gets a flat on a hub wheel or even a chain drive. It takes time to change and then there are different terrains. What is good for the road wont work as well for a trail. Then there is the convivence of having a smaller or lighter bike when hauling it around or traveling on a train or a small vehicle where a 20" bike is ideal.
For a great cargo hauler a 26" bike with dual motors and a large basket like the 26" dual suspension is ideal. It can haul 50 to 60 pounds as well as extra batteries.
My neighbor around the corner saw me riding home on a flat tire the day I came home from a 10 mile trip with the 1,800 watt brushless motor and was pointing to my tire and I said I will be back in a minute as will just hop on another bike and about 5 minutes later was riding the vintage 1990s DimondBack Outlook with the dual Bafang motors. :lol:
No. I would not trade all six or seven e bikes for a $5,000 down hill bike even if it were a Cannondale Jeckel with a 40 mph Geared BMC hub motor. However I will keep what I have and look for a deal on such a bike in the future.
I do not see how my vintage Haro V3 with a 3 kilowatt brushless motor and 8 mm chain capable of 45+ mph will be a half assed build though. Also the Giant Roam which is worth around $500 new with dual e bikeling GEARED hub motors each 500 watts with 22 amp controllers. Those e bikeling kits almost doubled in price so the bike with the motors is almost $1,000 new and the bike and hub motors are in excellent condition.
That is well over $1,000. Approximately 25 mph with the 700c front hub as well as decent hill climbing with 1,000 watts total and 44 total amps and all 21 pedal gears.
I fail to see how a bike like that is a half assed build. I do need to work on it as far as a new battery rack and re wiring but I have all the parts and they are in great working order.
I also have the 3 kilowatt motor , controller and Haro V3. The bike needs some parts and I still need to build the 60V LIFEPO4 pack but when I am finished it will not be a half assed build.
Thanks.
LC. out.
5/27/21 - 2:45 PM.
Basically any bike I build can be upgraded. I see no reason to upgrade any of the motors as 20 mph is still the federal law and street legal and all my bikes will do that.
Upgrades are wiring , brakes , pedal gears on a few but not as important here as NY as here I see the same mini bikes and gas powered bikes riding around for years with no pedaling. As long as the bike has pedals the police do not even look twice to see if there is a pedal chain. In NY I saw several gas powered bikes running up and down the street and a few days or a week later they disappeared. That tells the story.
My upgrades will be brakes and wiring as well as lighting and rear view mirrors. Better tires and tubes and my power meter DA. recommended. I bought 14 gauge wiring to be used on all e bikes up to 1,500 watts. I will be using 12 gauge for the 3 kilowatt brushless motor when I build it.
Then there is the batteries. Since I have been working on the Currie I stoped working on the LIFEPO4 pack but that will be for the 3 kilowatt motor exclusively. I still need to finish a 13S - 6P - 18650 pack to hook in parallel to the factory pack that is 13S - 7P.
That should increase the output of the 1,000 watt 26" hub motor on the back of the 26" dual suspension. The power meter will be wired so I can use it on any bike with XT 60 connecters and all my bikes have been upgraded to those.
My e bikes are not half ass builds. I use DC breakers now instead of cheap 15 amp taggo switches from Auto zone and am finally learning to install brakes. The Currie needs a brand new V brake on the front and will be getting that real soon.
I used the solderless connecters to redo the throttle wires coming from the throttle to the Greentime controller but the single wire going to the brush controller I used a spade connecter as the wires going to the throttle plug were way too short. I cut off a plug on one of the old brushless controllers that did not work and saved for parts. The spade connecter locks in so the throttle wires are perfectly secure. In the test video I just stuck the bare wire in the throttle plug slots for testing. I learned how to remove a spade connecter from the white plastic plug in a you tube video.
Yes. You can teach an old dog new tricks. I have learned so much here like how to run one throttle with two controllers. I can and will be doing constant upgrades to my e bikes. I will be working on the new batteries as well as the Giant Roam. I would like to build a strong durable battery box or boxes for the LTOs. It has to look really good and be very strong and durable.
Thanks.
LC. out.
11: 30 PM.
I rode the Currie to the bike shop earlier and got V brakes professionally installed on the front. It was a 19 mile round trip and started at 40V so was running low on the way back. I did charge awhile they were working on it but not long enough. It slowed down up a hill on the way back. Also the Bafang started making a noise about a mile from the house. When I shut down the rear brush controller the noise stopped so my guess is low voltage. The meter read 34V when I got home so LVC was limiting output current.
Other than that the chain stayed nice and tight. It did not come loose. I need to adjust the brake they installed though as it could flip the bike going down a hill. I mainly use the rear caliper brake which slows the bike down on hills. It held up well during the entire trip so my custom made brake bracket actually works good for the rear.
The front end shook when applying the front brake also so could be a spacer or something missing. I wanted the other bike shop to install the new forks but they only work on the e bikes they sell so will need to take it back to where I went today.
So basically the Currie ezip Trailz as aboyt 80% perfect. NOT 50% or half ass. Once I get the spacer or bearing in the fork and adjust the front brake the Currie will be 100% especially with a fully charged battery. On the way there it had plenty of power up hills. The first big hill I went up was only about half throttle.
I will hook up my power meter as a single battery pack so will work well. Power is 1,350W @ 36V so at 41V it should be pulling about 1,500W. Usually a fully charged 10S - 36V battery is around 42V so with 1V SAG 41V. If I were to run 15 - LTOs there would probably be really close to 0V SAG.
1,350W / 36V = 37.5A * 41V = 1,537.5W.
Please post when you can.
Thanks.
LC. out.
