DrkAngel
1 GW
latecurtis said:The Weller works. Not sure why DA said I was melting all the solder at too high a temperature and the Weller has the magic temp. ? I have to feed the solder way faster as is thinner and if I don't will just evaporate. The Weller is way hotter than the 60 watt irons. However the solder DA. recommended sticks way better than the cheap Wall Mart junk even though the Wall Mart solder says it has lead in it.
latecurtis said:Ok I did see the solder NOT sticking to the 60 watt iron tip. Not possible to tin. DA was right about the magic temperature. I could not de solder the 26650 cells with a 60 watt iron. Iip might be hotter but not larger. Not only could I de solder with the Weller but easily re soldered a wire no problem at all.
The "angle tip" you are using is a knife tip, for cutting plastic etc., might even be plated to repel anything sticking to it. Regardless, it is damaged and worthless for any type of proper soldering!
The 60w can be much hotter and transfer much less heat because it cannot maintain heat.
That is not your problem though ... You overheat (burn) your tips so that solder won't stick to it. A tip coated with solder transfers heat from the majority of the tip through the solder. A burnt, oxidized or charred tip only transfers heat through a microscopic contact point... that is actively trying to repel the solder.
Use a new heavy tip and keep temp below 400℃ (370℃ is ideal target temperature), clean, flux and "tin" (with solder) before 1st use!
Do not wire brush your Weller tip! It likely has some special plating that you do not want to wear off = destroy. Use a moist (not wet) sponge or rag to keep it clean, clean often!
All of your videos show you dripping cold solder 190℃ onto cold metal, then trying to heat it to bonding temperature, wrong! Load tip with solder, pause for 370℃ temp recovery, place tip directly against fluxed solder point and add some solder at contact point.
Oh, and piling more solder on top of a "weld" accomplishes nothing good, is wasteful and ugly - AKA LCMN.
