Mammalian04 said:
Sorry if I have overlooked it. Are the differences between the sine wave motor series outlined somewhere?
- Brushless KLS-S
- Brushless KLS-D
- Brushless KLS8080I
- Brushless KLS8080IPS
I was searching specs to find the most appropriate controller to push a lot of quiet power through LightningRods' Big Block kit at 72v nominal. It seems that the 4 series up above have different voltages am amperage but there is a lot of overlap with very different price points. Can someone clear this up for me or point me to where I can find a good answer. If a concise answer doesn't exist, I can reach out to Fany.
Thanks gents!
Mammalian04
As you know,KEB/KBL/KHB is based on trapezoidal waveform.So the noise at the starting up should be expected.
And the noise will be existed in the whole running.
KLS controller is sinusoidal waveform control.There is no noise for the whole operation.
Both KLS and KEB/KBL/KHB can do releasing throttle regen mode,brake switch regen mode and brake analog regen mode now.
The switch signal is valid to ground on KEB/KBL/KHB while you need to use 12V of KLS controller to activate the switch signal.
And KLS can support Android OS program and Microsoft OS program.
You need to do auto_identify function to run KLS controller to drive the motor.You don't have to program the controller KEB/KBL/KHB to drive the motor.
01050001:The 12V brake switch and motor temp sensor functions used the same port on pin1.
01050002:The 12V brake switch used the different port from motor temp sensor.pin25 is 12V brake switch while pin1 is motor temp sensor.
01060001:The 12V brake switch is pin25 while motor temp sensor is pin1.And we added the brake analog regen mode on pin2.
KLS8080I is designed for the motor with common three hall sensors.
KLS8080IPS is designed for the motor with sine/cosine speed sensors.
You can find the details in configuration in KLS8080I/IPS user manual.
When speed sensor type is at 4 for linear hall sensor(sin/cosin speed sensor),you need to use KLS8080IPS controller.
For example,we can provide Mars 1115 motor with sin/cosin speed sensor.
There are +5V,GND,Sin and Cosin port from this speed sensor.
