adam333 said:
Its always nice to see the pictures showing the bike progress under construction.
Like it of not, there is obviously a lot of work involved in this trike, imho, rborger73 can be proud of it.
just a question, the rear wheel is a 16" moped tire? which one did you chose? and what is the rim width ?
I believe it is a 19" moped rim and tire. Teslanav on here I got it through. Think it was laced in Washington state. Beautiful job. There are some motorcycle shops that lace rims here, but ebike motors I'd rather have someone do it that knows their stuff. I can't recall but I think it comes out to a 21 to 22" overall. 20" on the front. I had to go almost 20mph in a hard turned circle to get one of the front wheels to lift off the ground in testing it.
I still have to do a good video of it, and maybe people will get a better idea of the trike a little more. Not sure how someone thought I made and hung a couple side covers on the "flimsy" thing. lol This thing is a tank. Before I did the final touches on the body I had a couple people push on it like you would to check a tire being flat, or the strength of a fender. Ridiculously solid. I over built everything on it. I owned and managed body shops, so I absolutely could have welded up frames and done it that way. I may try to however sell all the pieces as a kit for KMX owners. My final frame I'll be producing will be a bit different but the part where the body actually attaches will be the same. This basically would be a bolt on kit. The rear deck could also be pre wired with all the components and sold as a kit with motor, body kit, controller, etc. The sides would already have the aluminum strips pre drilled and all they would have to do would be line the sides up, drill the holes in the seat frame and bolt it on. So from the beginning I wanted to avoid anything much over basic tools for assembly. Also cuts down on welding gas costs, and the electric required it eats up as well. Wire.. etc.
So cost, strength, and light way easy to obtain materials. Aluminum strips, angle, and diamond plate is available at any lowes or home depot. The deck plate was around 35 and I got it cut out by the shop. I have a full sheet metal shop, but they had better ability to cut it without cut off wheels, or saws. I could probably get it down to 20 to 25.00 if I ordered these pre cut.
For this trike I think there is about 80.00 of aluminum, maybe 8.00 in sheet metal, most of which was already scrap pieces since we have customers for the sheet metal shop. In reality the body cost 100.00 in materials. I'm building an aluminum seat frame just out of wider strips like 1" wide. Basically making the seat hinge at the very front, and making a latch at the top rear seat tube. This will allow the seat to be easily opened to gain access. There is a large area in the very back from the seat itself down to the rear deck for hauling half gallon of milk, loaf of bread, probable 3 or 4 more small items. Or throw the charger in there layer it with some foam.
So maybe another 40.00 total in materials for the body. Under 200 anyways. Now probably looking at 250 or 300 doing the body out of fiberglass and or carbon fiber. Now if I can produce each body the same and have molds and all my materials pre cut and ready to go. Someone could put one together in a weekend using a stock kmx tornado frame. Lots of options here, but the key for me was again strength, low cost and easy to obtain materials, as light weight as possible. And this is a steel frame even, not aluminum. I have to price out all the components yet for what is on the tornado to see what I'll save doing my own frames. I imagine it will be considerable just due to the shipping costs of the trike. 2 or 250 I think in shipping alone. Soon as you sit down on the thing you start smiling.
I've got 14,000 miles on a hard tail ebike that weights 115lbs. So when someone questions the comfort of this cushy seated legs up resting etrike, I think we must speak a different language. lol I suppose I could have built a sketchy steering huge bulky thing instead.
