raylo32 said:
For instance, one thing I am interested in doing this winter is upgrading the bearings in my TSDZ2. I have gone through the thread and even used the search function but there are hundreds of instances of "bearings" and I can't find the definitive answer as to which specific bearings work best with the least amount of fitment hassles. Lots of back and forth, many different solutions, but hard to find the specifics. We really need this sort of stuff in a sticky.
I wrote this up for someone a while back but never did anything more with it. After all this, I really just wanted to get on with riding my bike again. If you search through my post history you will find many photos documenting my rebuild, and if anyone would like to compile it all into a wiki page please be my guest.
In addition I recommend reading these threads for some more discussion of the various issues we are trying to resolve.
https://endless-sphere.com/forums/viewtopic.php?f=28&t=98361
https://endless-sphere.com/forums/viewtopic.php?f=28&t=108017
First up be aware there are differences in the original and later motor revisions with regards to shims, torque sensor construction and number of non-drive side bearings.
I did replace most of the bearings but in particular the ones on the spindle don't improve play much simply by replacing them however you will get a longer service life. (The only bearings I didn't replace were those in the blue gear, but I did replace that gear with another the same while I had the opportunity - even though it looked fine. Pictures of motors full of metal filings from chewed brass gears convinced me to stick with plastic.)
I experimented with shimming the races but in the end used an equivalent to Loctite 641 medium strength bearing retainer (RS Components R41) to affix the non-drive side ball bearing to the spindle as well as within the motor case. You will need shim washers between that and the circlip, and on the drive side between the torque sensor and sprag clutch. I bought an assortment of thicknesses and experimented and yours will be different.
https://au.rs-online.com/web/p/retaining-compounds/9082770/
Shim washers are:
ID 15mm, OD 22mm, thicknesses from 0.1mm to 1mm
ID 30mm, OD 42mm, thicknesses from 0.1mm to 0.3mm
That retaining compound seems easily released with a little force such as tapping the spindle out with a hammer or pressing things in a vice. It should hold well enough for rotational forces though. The higher strength stuff is pretty much permanent and requires extreme heat to break free.
I also added highly sealed ball bearings in place of the dust seals. I affixed the outboard non-drive bearing the same way, but on the drive side only applied compound to the inner race. It's an interference fit in the cover so didn't look like it would spin, however I added silicone sealant to hold and waterproof it with the idea that it would be easier for removing the cover in the future. You can't keep the dust seals with the added bearings, except on the non-drive side where you need to use a standard width bearing instead of the wider version I used.
Replacing the roller bearing on the torque sensor was tricky but not overly difficult, I think I made a post about that and how you need to desolder the coil to allow removal of the hall sensor so you can slide the old bearing off.
I noticed a big improvement in play by replacing the sprag clutch, not within the clutch itself but related to how the inner race was machined.
I also created a better fitting key to hold the sprag clutch. This is the part I bought, I needed to cut in half and then file down, the length allowed me a second try in case I messed up the first one.
https://www.smallparts.com.au/store/item/k080007003600ac/?v=5166
Unfortunately I'm in Australia so these suppliers probably won't be of use, but you can get an idea for the parts I used.
Sprag clutch - CSK30P 30 x 62 x 16mm with internal key way
generic brand
https://www.ebay.com.au/itm/123904447578
Spindle, non-drive side - 6902RS (old version uses two)
SKF 61902 2RS1
https://au.rs-online.com/web/p/ball-bearings/1440863/
Spindle, new outboard bearings - 6902RS x 2
Drive side: Enduro 6902LLUMAX
https://www.scvimports.com.au/product/5544-enduro-6902-15x28x7-max
Non-drive side: Enduro 6902LLUMAX-E (extended 10mm inner race)
https://www.scvimports.com.au/product/5545-enduro-6902-15x28x7-max-e
Torque sensor - roller bearing HK2214 x 2 (older motors may have been the 2mm narrower HK2212)
INA HK2214-RS-L271
https://au.rs-online.com/web/p/roller-bearings/1946937/
Reduction shaft (outer), between pinion gear and blue gear - 6001RS
Nachi 6001-2NSE9CM
https://www.ebay.com.au/itm/272114032787
Reduction shaft (inner), in motor housing - 608RS
SKF 608-2RS or 608-2RSH
https://au.rs-online.com/web/p/ball-bearings/4419953/
I bought the 2RSH which have stronger seals but are overkill and increase drag.
Motor external, end of spindle (in case) - 696RS
generic brand
https://www.ebay.com.au/itm/151628723903
A whole new blue gear with bearings is cheap and less hassle, but here are those details for completeness:
Blue gear, bearing - 609RS
Blue gear, roller clutch - HF1216 (or FC12)
Blue gear, washer - 8.2 x 11 x 0.5 (spindle is 8.0mm)
