fairlyfaded
- Joined
- Jun 19, 2009
- Messages
- 11
Greetings all,
I am in the process of putting together a single wheel electric trailer for hauling goods+dog to and from work. I have two hub motors, a 9C laced to a 20" rim and a 500 watt Bafang CST geared hub motor laced to a 26" rim. For the past month I have been using the Bafang to pull around a kids trailer with my dog in it. Unfortunately I recently toasted a hall sensor inside of the Bafang due to running the thing too hot, so now I am going to switch to a single wheel trailer pusher.
Anyways, I took apart the Bafang motor to try and see what had happened to it. While I had the motor apart, I figured I would measure the no load power consumption of the thing.
With a 44 V battery, I measured 2600 rpm at the motor, and a no load current of around 6 amps (or 264 watts!). I was amazed! First, I was amazed by how fast it was spinning (it was never clear to me what rpm/volt my motor was due to how dubious the website I ordered the thing from was). Second, I was amazed by how much power it was chewing through! 264 watts to do... nothing but make a toasty motor and controller.
Next, I tried the 9c motor. To be fair, the 9c had a 20" rim laced to it (no tire) so presumably suffered from higher windage losses.
With a 44 V battery, I measured 800 rpm at the motor, and a no load current of around 12 amps (or 528 watts!!). Good god!
Do these numbers seem correct? Obviously I'm pushing the motors quite fast due to no load. With a load, the speeds would drop by... 30%? Which should drop the core losses considerably.
Regards,
Michael
P.S. I should note that I am using a 6 fet IR4110 Lyen controller. At no load, the motor controller losses will mostly be from switching. I'm not sure how high the switching losses on one of these guys should be... But I would have guessed that these controllers are in the 95% efficiency range even at low power...? Then again... a few hundred watts isn't that low power.
Regards,
Michael
