dogman dan
1 PW
Well, I'm usually full of crap when it comes to the electronic theory,,, But the hot motor does draw more amps, or turns more amps into heat than a cool motor, or something like that. You can feel it happen as you melt your motor. It's the same feeling as sagging sla's.
I'm running 36v on the commute home. I have heard air vents help, but by the time I tried it, the motor was toast, and the vents let the smoke out real good. I'm thinking of tying some cotton strips around the hub, inside the spoke flange, and keeping it soaked with water, but so far, I'm not seeing hub temps much over 160F measured inside, and cover temps at the same time are around 112. I think this brusheless aotema may be albe to take the heat at 36v. It should get hotter when its really blazing, but right now the hub seems to reach an equilibrium at around 165F. In colder weather, it reached the equilibrium at a lower temp.
