jonnydrive
xenodius said:I poked around in the config file a bit (very nice of you to comment it like that) but for faster debugging just loaded your configuration onto my controller to test it live using PC BacDoor. Right away I noticed that contrary to the mobile app images you showed that the Cutoff brake sensor source and Regen brake source are both 0 (brake 2) so you are likely triggering cutoff and preventing both regen and throttle. Changing your Cutoff brake sensor source to network or an unused input should do it. Did you update your mobile application parameter dictionary with the previously attached file? Here's my config-- I'm also using Brake 2 for regen and have Cutoff brake sensor source set to Network.
Also you said you could finally set brake 2 pullup to on, but it is off in your config-- as it should be for a hall throttle!
Thanks xenodius,
the problem was exactly with the cut-off sensor!
In Kelly Controller (KLS) for enable analog regeneration is also needed to configure the cutoff switch.
I am not sure if is related but I also set the various battery parameters.
Many thanks
J
