opperpanter
Not possible.
Whitehawk said:Hi all,
Do you know if it's possible to lower under 38v the low voltage cut-off of the 48v BBS02 ? With the aim to use 36v battery ....
Thanks a lot !
NeilP said:Just looking at helping with a BBS02 kit for a friend.
So posting to subscribe to this thread and also a couple of questions.
Buying from CellMan (em3ev). 48v 750w probably with c965 display
44t front 11T smallest rear
Will need to build up a programming cable. Already have a CAV3 cable so need to make up adapter. Just wonder if anyone found a source of the correct plugs to make program cable ? Or are we still limited to 'hacks' with jumpers to the motor (controller) plug.
With the spec as listed, 48v/750W 44T /11T rear on 26 inch wheels, what is likely top speed?
This is the bike
DaDo.Bzz said:[
48kmh without peddaling
I have two bikes with a 750W BBS02. The 26" tops out at 43km/h f full throttle no pedaling.DaDo.Bzz said:NeilP said:Just looking at helping with a BBS02 kit for a friend.
This is the bike
tomjasz said:I don't see any real advantage or disadvantage between display versions. It's really more about esthetics IMO. I prefer the 961. Again because it fits my layout well.
But is it useful? It really doesn't offer me much...tommie said:...the 965 has a Watt meter if it makes any difference.
I found it inaccurate and exchanged it for a 961. I compared readings to a CA3 with a shunt. I found it not only inaccurate, but inconsistent. I'm assuming my CA3 is accurate. If it were always off the same percentage value it would have been useful. But I only tested one 965. It may have been an isolated problem.NeilP said:For me, a watt meter is the one I would prefer.
tomjasz said:BTW The wattmeter on the 965 only displays the wattage being consumed at that instant. Useful to avoid a meltdown, otherwise?
tomjasz said:There really has never been an "official" cable. I humbly suggest you don't hurry into programming. Ride first. Review your ride and decide if the changes discussed are of value.
alfantastic said:Ref: BBS02 48v 750w 25A
I've read quite a bit on how the Bafang's controller programming works, but I'm still not sure on one thing.
Does the controller act on signals from the wheel sensor to reference data from the Basic menu and decide how fast to spin the motor, or does the Limit Speed(%) simply spin the motor at a percentage of its maximum spin speed, regardless of how fast the bike is actually travelling?
