Back on the original question, for a sensorless controller, there will be 3 forward and 3 reverse combinations for the phase wires. It won't make any difference which one you use.
dogman said:Probobally the controller losing sych. Personally I'm not sure sensorless is ready for high rpm's. I had a similar problem with a 40 amp 72v sensorless controller. I ended up trading it in for a sensored one. Then I got a sensored motor and kept the aotema one for use with the stock 48v controller.
NeilP said:As for CA not reading speed. Have you got the remote speed sensor type ? The one that has the seperate sensor and the magnet clipped to the spokes? If so you need to set the Pole Count in the setup menu to 1
Spacey said:I've been having a spot of bother with the new 12 Fet Sensorless controller from Lyen. My setup is:
9C 2807 26inch wheel 12awg phase wire upgrade and cooling holes made.
20 Cell Headway 16ah pack
12 Fet Lyen sensorless edition
No load speed is perfect all the way up to top speed. Bit of a grumble judder when accelerating hard past 10mph....but for me the problem is that at higher than about 25 to 27 mph if I give the throttle more than 75% the wheel judders like it's about to go into reverse and the amps shot up to 79 amps peak.
The wheel was very very hot with all the juddering but the contoller was very cool. I'm happy with the contoller other than the juddering. With a 26inch wheel I can't be doing that many rpm? It really feels like the timing goes way out of sync as the rpm get higher.
This set up is good for 37mph, was able to use full throttle when going down a hill only using 9amps, but as soon as the amps are needing I.e on the flat the juddering kicks in very strong.
Does anyone have a fix?
o00scorpion00o said:Same problem for me with Lyen sensorless and magic pie.
It makes a surge of power than always at a certain speed it pulls back while making that awful noise and a bad vibration. The whole bike shakes violently, but if I ramp up the throttle slowly it is fine.
feyris said:o00scorpion00o said:Same problem for me with Lyen sensorless and magic pie.
That's exactly my issue.
It appends during acceleration, or during climbing. It's very annoying, and can be dangerous (no power when you just jump in a traffic circle...)
I don't think it's coming from your motor because of burned sensors, mine is fine and never had sensors.
snellemin said:Ahh, Nice that you found your fix to your throttle Scorpion.
Beachcruzer said:Success! With some input from Lyen I think I've finally got this thing tuned properly.
First, I programmed the controller for 30 amps rated/50 amps phase, as Lyen suggested. That should have reined the power output back to the low-2000 watt range, but it had little discernible effect--the controller was still pumping around 5000 watts at WOT (72 volt lipo pack), efficiency was 107 wh/mile, and it was losing sync at high speed.
Then Lyen told me to change the RShunt value in my Cycle Analyst from 1 mOhm to 2 mOhm, and amp limit from 80 to 100. (It doesn't go up to 100, so I set to 99). I did that, and the controller magically calmed down. Peak wattage is a more reasonable 2,500 or so, efficiency is 45 wh/mile, and no sync issues. Wound up to 40 mph with no problems.
I have zero clue why the controller didn't function as programmed until the CA was set properly, but there you have it.
