feyris
Beachcruzer said:Success! With some input from Lyen I think I've finally got this thing tuned properly.
First, I programmed the controller for 30 amps rated/50 amps phase, as Lyen suggested. That should have reined the power output back to the low-2000 watt range, but it had little discernible effect--the controller was still pumping around 5000 watts at WOT (72 volt lipo pack), efficiency was 107 wh/mile, and it was losing sync at high speed.
Then Lyen told me to change the RShunt value in my Cycle Analyst from 1 mOhm to 2 mOhm, and amp limit from 80 to 100. (It doesn't go up to 100, so I set to 99). I did that, and the controller magically calmed down. Peak wattage is a more reasonable 2,500 or so, efficiency is 45 wh/mile, and no sync issues. Wound up to 40 mph with no problems.
I have zero clue why the controller didn't function as programmed until the CA was set properly, but there you have it.
Good news!
I have the same problem, but I don't have a cyclanalyst.
I will try to change the amps value on my controller, I'm waiting a new usb uart (burned the last one lol)
