Dui said:I assume that by "cylindrical options" you mean 18650 cells that output 3.7V, so not LiFePO4 chemistry.
In which case, there's something to be aware of regarding capacity: it declines differently with time between both techs. The decline in capacity is much faster with most of the Li-ion techs than the LiFePO4, meaning that while it's true that you 'll have more capacity today with this pack, there's no guarantee that it will still be the case a few months later.
In any case, capacity ratings are very tricky to interpret, some cells with lower marketed capacity will actually have more usable capacity than others under higher loads since they'll heat less, it's not as straightforward as reading whatever is in the spec sheet from the manufacturer. In my humble opinion, it is better to focus on low internal resistance cells.
22A per cell is quite a lot, one of the best cells I know is the Sony VTC5D and it's rated at 25A continuous. It can do 35A peak so you're still in the safe zone, but not a lot of cells can match this kind of specs so if you want the pack to last a while then choose wisely (or overbuild it) :wink:
Do you already have some preference regarding a particular cell ?
I replied to this but it seems the post got lost.
I have read that these cells can degrade quicker, but it's hard to find testing data on what kind of degradation to expect. The good news is I don't expect to ride this every day. Maybe a couple cycles a week excluding when it's particularly cold out. At that rate it would take 5 years to hit 500 cycles. If they can retain even 80% of their initial capacity at that point, I'll be happy enough with them.
22a is a lot, but I'm expecting that to be the absolute max peak amps I pull, not continuous. This isn't a highway cruiser! On my local roads I don't expect to be pulling more than 7000watts very often, I just want to have some margin so I can get up and go if I need to.
As for cells I was mostly looking at the Samsung 40T and Molicel P42a. I'm definitely open to other suggestions though.
I was initially really tempted by the salvaged but "new" model 3 cells BigBattery is selling, but the low amp rating and high operating temp make them not a good fit aside from the price per KWH being darn tempting.
