Hey all. Trying to plan out my battery for a kymco spade conversion. I have a QS 138 90 and EM200 on the way. I also put a pre-order in for a Nuclear 24, I really like the screen it has for tweaking settings.
I keep going back and forth on what type of batteries to use and I would love some input on my options. The space I have for the battery is pretty limited. Essentially it's a 6" x 12" space, 8" wide, with another 6" x 6" x8" space underneath it.
Ideally I'm aiming for about 3KWH if I can make it, but critically I don't want the battery to be the bottleneck of the system. I want to be able to pull those 200 amps peak if needed on the EM200.
Cylindrical cells seem like the typical go-to. It looks like I could fit 160-200 21700 cells. Samsung 40T or Molicel P42A have high current ratings that should be enough for my needs as long as the bus bars and nickel strips are sized and build appropriately.
I'm of course also concerned about safety. Has anyone done cell-level fusing on these cells? It doesn't seem to be very common with high-amp builds.
Then there's pouch cells. In theory they are ideal, but when I find a cell that's dimensions fit my needs it's often hard to find a good supplier. The EIG C020 are perfect, and have great kits for assembly, but I can't find any supplier in the states.
I've looked at other pouch cells but I'm also having trouble finding reliable information for what the best way to assemble packs from these are. I've seen people spot welding them, using PCB bus bars with through-bolts, crimping them together with rivets, etc. But there isn't a lot of info on which method is best and why, it often seems like people are just winging it. I like the idea of using pouch cells a lot, there are good reasons why Zero, Energica and others use them but it seems like the resources for DIY packs are scarce.
I think if I had a bigger bike prismatic cells would be the obvious and easiest choice, but their sizes seem to be incompatible with my size and voltage needs.
Any suggestions or insights would be greatly appreciated.
