stack of 16cells not including termination or BMS = 110.4mm * 165mm * 227mm
Bobocop said:I don't mean (by what i'm saying) that the price is to high for the quality, What i mean is that it's to high for the average person to afford.
You must be one of those rich little kids that your parents work hard to support your habits.
Try working for it, and then you'll understand mypost.
tropmonky said:@John in CR
Bad cells are just a fact of life and if a simple easy and effective non solder/welding way of putting packs together is found then I think most people would want to go with that.
On the other hand you do have a point though.
I'd like to get a 12 cell 20AH pack going!
liveforphysics said:CroDriver said:RoughRider said:@Cro
YOU ARE CRAZY...
lets say 300V*2000Amp * 2 = 1200kW...CRAZY
Ahhmm, thanks...?
5 20 Ah cells and 6 15 Ah test cells will be on my desk in a few days so we'll have more data in a couple of weeks
Still waiting on the fancy scope to come, and I will have graphs of 450amp discharge on the 15Ah cells, and 600amp discharge on the 20Ah cells. They are very much capable of it, and in a drag vehicle like you're proposing, he wouldn't be a concern for them at all.
TylerDurden said:I posted this image of corrugated alu earlier in the thread, but that stuff might be hard to get.
Polycarbonate (lexan) fluted panels would be a way to get cooling between the slabs; it is readily available and less expensive than ally.
Avoid fluted polypropylene (coroplast), it will melt. IIRC, someone mentioned 'honeycomb' panels, that would insulate (bad).
cell_man said:Hi Chris,
I've got a design engineer friend visiting China at the mo and we made some progress on the box today. I think we've got a workable solution using 2mm aluminium sheet for side panels and 0.3mm between each cell. Most of the first box is made up now and I've got it fairly clear how it's going to be finished off. After that it's just a case of making the parts and then I'll try to get through them ASAP. Hopefully get the first shipment with 2 or 3 packs on the way to you soon
After working through the build a bit today I feel much better about the whole assembly. Maybe I've been worrying a bit too much. It really helps to be able to talk it through with an experienced design engineer, trying to just sit here and work through all the little details has been so difficult. A bit of re assurance and some new ideas is like a breath of fresh air
snowranger said:I am pretty sure my Ping died from vibration and shock rather than heat. All bad cell groups were at the ends of the pack, and there were obvious signs of fluid leakage at the bottom of the pack.
Yeah, that's why I put foam liner at the bottom where the battery sits. (Or, if it's in a bag, I don't use anything because the bag material itself has "give" to reduce peak shocks and evenly distribute the forces.)
A layer of cork sheet at about 1/4 inch thick is a good dampening material - which I use in my pack.
Assuming you charge every 20 miles, that's only 250 cycles you had on your Ping. Significantly lower than the claimed 1000+.
snowranger said:I was using that interlocking foam they sell at Costco for playrooms and such. Tried to make it tight enough that the pack wouldn't move around. Even so, the constant jarrring somehow wore down the cells.
Lots of rubbing goes on inside the battery bag or box. Hopefully the shrink wrap used now will help with that vs the duct tape that was on the early packs.
That's why I make the super tight fitting inner boxes custom fit to my pings. There is just no movement at all, and all the rubbing goes on on the outside of the tight box. I have some areas on ping 1 that rubbed quite a bit of the aluminum box away, but remove the battery, and the duct tape still looks cherry.
On some nicad packs I have, it didn't take long to start putting some serious rub marks on the cell cans. I didn't protect them so good, and quickly realized I needed to do more, even with metal canned cells.
maxvdh said:TylerDurden said:I posted this image of corrugated alu earlier in the thread, but that stuff might be hard to get.
Polycarbonate would be a poor choice, it has nearly identical thermal conductivity to polypropylene. Aluminum would be a good choice but I'm not sure why you'd want to use corrugated material unless you were running a coolant through it. Paul's plan sounds like a good one. I plan to cool my batteries similarly with thin Al sheets between them (possibly just Al foil or flashing) and clamping that to a heat exchanger with coolant running through it. Probably overkill but I want long term reliability.
