Hey guys. I'm working on a new inrunner motor design for high powered electric bikes. This will be a suggestion thread. Some things we need to settle on are...
Motor OD (80mm stator, 86mm-88mm case)
Motor Length (40mm short motor to ??? for long motor)
Shaft Length (30-40mm)
Shaft OD (12mm)
Motor Kv (~130, ~200 versions)
Max RPM (15,000)
Motor OD is the most critical since it's very expensive to make a new die set. The other parameters can be changed after the fact without much trouble. I'm also planning on making the motor with a stub shaft at the back for an encoder. This way the motor will work with any drive you can put your hands on.
Response to http://www.endless-sphere.com/forums/viewtopic.php?f=28&t=7180&p=121900#p121900
This motor will be way more powerful than the Maxcim at a smaller OD and bit more weight. The gearbox is just an idea...nothing too serious. Also, 100mm OD might be possible, but a short large diameter motor is not the best configuration for a radial flux motor. They really need to be close to square (stator length=diameter) to keep things efficient. Also, I want to try to keep the weight pretty low, we're using some high end materials on these motors so costs will start getting out of hand. It's better to use steeper gearing with a small motor than go with a huge motor with low gear ratio.
http://www.xeramotors.com <-my webpage...has a few pictures of my 6050 motor..one of 2 that will ever be made![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Shaft OD (12mm)
Max RPM (15,000)
