thx for the info.
problem1 solved: Some wobble in the Pas disc caused irregular pulses. Analysed this with an Arduino. A washer below the disc solved the problem.
problem2 solved: Speed sensor is at the front wheel. Controller seems to ignore it for max speed setting. It seems to use commutation speed. I now setup 9kph limit, and it throttles motor speed from 43kph (without limit) to almost exactly 25km/h reliably. A bit strange, but it works perfectly.
Thx for your manual offer, I have it. There are only 3 options that can be setup: Speed, Wheel dia and unit (kph/miles)
After some test I can confirm that the S06P in fact uses torque mode throttle. It accelerates to full speed at all power levels, but different torque. This is what I searched for YEARS. so happy with this controller now
The S06P is will be square wave, since the manufacturer says there are 2 versions: S06P (square wave) and S06S (sine wave). Sine wave one costs a bit more, i will test this using a scope tomorrow.
Why exactly should it not be possible to use the S06S with the sensorless emulator board from the S06P? Not enough space internally, but externally would be possible i guess?
