slaphappygamer
The RadRunnerPlus is the longest bike we have. It's 71.5", almost 6 feet long. Both tires fit flat on the rack.
Nvreloader said:Guys
Here is the one I got coming,
all steel, can be easley be adapted if needed, also the spacing of the wheel wells allows for each wheel
to sit in a recessed pocket and a bolt is inserted over the rim and thru the side carriers supports,
locking the bike in and to the carrier rack, I'll also use HD ratchet straps to secure the bike better.
YMMV
Tia,
Don
https://www.amazon.com/gp/product/B07YPRLPLY/ref=ox_sc_saved_title_3?smid=A2OSE6G7MS58ZO&psc=1
That should keep em safeNvreloader said:Gobi
I plan on using a couple of 6' long ratchet straps,
one on each side with soft wrap straps (motor cycles types) one off each side of the seat post stem,
that will keep the bike straight up/down and pulling down into the wheel well dropin's spots etc,
with the bolt thru over the rims, I don't think it will move.........LoL
ps, and if I need to change and add anything, I have a wire feed welder.
Tia,
Don
Zeus99 said:For heavy ebikes I would suggest the one that attaches to the trailer hitch. 100lbs+. You roll on to it with eaz as it has a small ramp you can use and use straps to secure it.
https://www.amazon.com/Direct-Aftermarket-Motorcycle-Scooter-Carrier/dp/B014VC5H64
pullin-gs said:This is my setup.
Carries two fat ebikes.
Using this 22x60" aluminum hitch carrier:https://www.amazon.com/dp/B07QKGS149/?coliid=I2MBVE3V61N0BN&colid=H89155HI0080&psc=1&ref_=lv_ov_lig_dp_it
Center post is 2x2 round steel pipe. Uses tie down straps.
pullin-gs said:pullin-gs said:This is my setup.
vanturion said:I went with the future proof 1UP Super Duty Single rack (225 lb total capacity)
Really nice and well-proportioned without being too far out. No contact with my 710mm handlebars en route. I also use a strapped 600D bike cover for anti-theft (or at least to decrease the chance of crimes of opportunity). Only minor caveat is the spiked pedals need covering during transport to prevent wind-tears for which I used bubble-wrap and rubber bands.
