I will make a KISS scenario.
You all are experienced bikers.
ebiking is but an extension of biking.
You are now on a public road and you've just fitted a new and very powerful disk brake,
or Vee pads, new super-stoppers, best-rated brand, to the front wheel.
A child darts into the road just
too quick. You panic; I
sure would.
You instinctively grab for that front brake handle and stop fast...perhaps too fast.
You either skid and lay down the bike or you go over the bars with the flipping bike after you.
Alternatively, say you have a rear-wheel-brake-only, bike. You are instinctive and accustomed to its braking characteristics;
the coaster brake works identically the same in wet or dry conditions.
A good, soft compound, slick tire stops practically as fast on wet pavement (not sandy or muddy) as it does on clean and dry asphalt. We don't need or want tread on clean asphalt roads. Nor do we want hard-inflated tires; they are poorer at adhesion
The child, or cat, or squirrel dart...you, on your say, coaster brake bike, LEAN BACK and
brake.
At worst, you fishtail, but you are in control.
You
can miss the object. You
can recover your poise in an instant.
Now, we are NOT going 30mph in these two, imaginary, instances;
we are going at bike speeds: under 20 mph or so.
And we are not going downhill from Pike's Peak, plus, the road is level, not a steep down slope.
No need then for a front brake. See? It's all in the conditions of your locale and in your skill level.
For me, I've had front brakes before and I have used them correctly, for the most part.
I never had but one accident, and that was because I was a 13 year old going just a few miles-per on a slimy, wet sidewalk.
I gripped the Varsity's front brake too hard. Locked the wheel. Fall down, ouch. Scratched the new bike, a birthday present.
YOU won't do such a thing, but a beginner or a panicked rider =can conceivably= lock the front wheel, which lock-up
lays the bike down or puts it totally out of your control (you may even fly).
Coaster brakes are rugged and reliable if you keep the machine in good order.
They don't stop a bike so very fast. How often must you stop instantly, anyway, if you keep sub-25mph on your ebike?
I've seen in person, too many bike accidents, and know that the damages done are to the rider, and increase in severity in log proportion to the speed the bike was running, or hit by a fast moving car.
BUCKETS OF BLOOD even at a mere15mph.
So: if we use caution and know what we are doing and why we are doing it, either system can be called "adequate";
depends on so many factors. Brains are the most important factor, not a super-stopper front brake, not in most emergency situations.
This is merely my opinion and devil's choice of two kinds of =possible evil results=.
Your needs and skills, guys, vary from mine. Do as you like in choosing a bike.
That's what choices are all about here. Make your choice and learn to brake under all conditions, panic, wet, slush, etc,
using whatever braking system you like. I like rear braking for the reasons stated. I am not going 40 per down long hills,
or I'd FOR SURE have a front brake, preferably a disk brake.
PS: and this is in red because I feel passionate now: HOW MANY OF YOU bikers have ever come close to the edge of front-braking
just a weeeee bit too fast or strong?
I know that I've come close to the limit of front tire adhesion, or even, nearly, 'pulted myself over the bars
in experimental panic-braking situations, practice braking efforts, made in order to test my limits and those of the machine.
I cannot fatally err with a coaster brake; not in the wet, not in the dry, not at all.
The coaster brake always, always, works the same way; it is a no-brainer, the coaster brake.
You just MUST keep the chain and cogs in good order, for, if the chain falls off, you are busted.
Keep the coaster-braked machine in good order and it cannot ever give you any such nasty surprise as "no brakes at all!".
No sudden need to panic stop in real life riding has ever presented itself to me.
But, a cat or raccoon will, someday, run in front of my bike, and if front braked, I will come close to losing control due to a panic.
Maybe you won't do that because you are a better rider, but I will do that too-fast-front braking, eventually with a front brake of real power. So, no front brake for me, thank you.
BUT, again, I do not have long downgrades to descend,
which long grades would/could easily cook a coaster brake.
In which case of hilly locale, I'd have front braking, and use it most all the time,
and alternate between front and rear in order to not burn up pads, or fry the coaster's internal grease.
PPS: and my fron-and-rear vee brake bike tests were formally done over two years ago, way back when I had that blue Currie Mongoose retro cruiser bike. It had no coaster brake, just rim brakes. I put super-quality pads on the front, OEM pads stayed on the rear.
See my earliest postings about the blue bike here, still on record. That bike could stop on a dime!
I had it fitted with the same leaned-back Thud Buster that I use today.
I LEANED WAY BACK for my braking tests.
The Bontrager Big Hank slicks then used, and still in service today, are so grippy, and the pads I used up front were "super duper" efficient,
and I had to air that front tire to at least 30 PSI, to avoid terrible wrinkling of the supple sidewalls of the front tire taking all that strain.
I COULD EASILY CATAPULT MYSELF OVER THAT BIKE. I never did catapult, but I came so close...on purpose...to learn....
....SUPER tires, super pads that Sheldon Brown sold to me; I did hundreds of panic stop tests, in order to teach myself the limits,
that, in an emergency, I would not take a header, or, on muddy pavement, LOCK that front tire and
faw down, BOOM.
No matter my practice: I know that if an object darted into my path, I would reflexively brake too strongly and suffer injury in result.
YOU might not, but you are not me. I live (figuratively) in the year 1898:
one of the very first coaster brakes. note the oiler-cap? note that it is not yet perfected,
and the chain is that first generation "block chain"; and the "Doolittle" (unfortunate name!),
does not automatically release when you ease-off the back-pedal-pressure.
KWYADAWYADI, both then and now?
