Hi guys,
Frustrated with the performance of the TSDZ2 750W, I installed an LM35 temperature sensor as per this thread and flashed emmebrusa's latest OSF so I could keep the original VLCD5.
It seemed to go ok, but when I got it back together again and turned it on, the display read "62.4mph" (Soc%?) and then "E02" with no power. After turning it off and on a few times it did start to work and I pressed 'lights on' to show the temperature as per configuration and it read "1.8", but soon got E02 again.
Error 2 is listed as "Motor hall fault or motor short circuit", so I opened it back up to inspect. Sure enough, I had fitted the big plug (hall sensors?) back to front having misinterpreted the connector. So I corrected this and put it back together again, but still got E02 intermittently.
So I opened it up again for a more thorough look and found that there was a poor connection (loose but not shorting) from the output pin of the LM35. So I improved this and put it back together, testing as I went. All seemed well until I was ready to try riding, but then E02! I could however get more sensible temperature readings after (around 20-21) and when E02 is not showing it works great!
But now I am at a loss as what is triggering E02. I wondered if it could be something shorting on the case because I haven't seen E02 when it's still open, but all the connections look good and are well insulated. Probably I should disconnect the LM35 and test, but I can't face opening it again right now and I don't know what I'd do with the results. I also wondered whether I could have damaged the pins on the hall sensor plug when I reverse connected it, but I did check and it looked ok.
Any ideas?
Thanks!
Any ideas?
Thanks!
