camperman1000
100 µW
- Joined
- Apr 30, 2019
- Messages
- 7
Hi everyone,
Hopefully I have posted this in the right section. As the title says I need to convert this battery to 12v output and make it a 12v charge as well. I will use a 200w panel and charge controller. This is the battery https://www.goldenmotor.bike/product/48v30ah-lifepo4-battery-in-a-stainless-steel-case/?currency=CAD.
I opened it up and it appears to be wired as 3s16p. Am I correct in thinking that I need to separate it into 4 separate 3s4p packs then hook those 4 in parallel to get the 12v 120ah ?
So far I think I need 4 separate 12v4s BMS modules one for each pack... and the 12v coming in from the charge controller will be sent to all 4 of them.
If im on the right track here... can someone point me to a decent BMS I should be looking into on fleabay or amazon?
Also, here is the solar panel and controller I am currently thinking of ordering. https://www.amazon.ca/ECO-WORTHY-Mo...00w+panel&qid=1556646885&s=lawn-garden&sr=1-9
Thank you!
Thank you!
