Yea you do have a point. The rear hub runs perfect. It very quiet and smooth. My first controller that has power assist levels as well as my first twist throttle. I really like it.
The controller for both motors is 30 amps. The hub kit came with a 35 amp fuse but 30 amps stated on the controller at 48V and 1,500 watts. Doing the math 48 * 30 = 1,440W. Therefore it is not a true 1,500W motor. It is rated for 35 mph. It does 33.5 mph.
I have seen other kits for the same price boasting 40 and even 45 amp controllers. Both also with the speed settings. I might get one next year for my 700c. I have two but neither are full suspension and every time I ride it I like it even more.
The main purpose for the front was to prove I can. I tightened the chain up more using several zip ties on the chain tensioner. I think it could be useful off road for traction as well as steep hills.
It is geared for about 32 mph so don't even use it < 20 mph. When I am cruising 25 to 28 mph in level #4 power in the rear I will press the throttle for the chain until I feel it kick in for a few seconds then let off it and just use the rear.
Also it is experimental. Since chain drive motors are still way cheaper than hub motors I could build dual chain drive e bikes with even three motors in the future. Two on a rear rack and a front chain like that in the picture. Another reason for the build was to be able to mount a front chain to the fork and still have full function of the suspension fork.
My other front mounted chain in the past were not on a suspension fork and used 1-12 by 1-1/2 pressure treated deck railing. I also used BMX style handle bars for three points of contact. Two for the handle bars and one for the fork. If I replaced the wood with steel bed frame and used grade #8 bolts or a welder it could be possible to install an 1,800W brushless motor or a 3 kilowatt.
Chain drives may be out dated but try and explain that to a biker.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
There are a few electric motorcycles that run hubs but the fastest ones like the zero motorcycle and FX motors don't use either. They are belt driven.
In fact that type of mount would be perfect for a belt conversion. However one of my favorite sayings is "if it is not broken do not fix it. I can always attempt a belt drive on another build. The full suspension is my flag ship build. It expresses my building prowess. It will turn dozens of heads out on the road.
There are thousands of e bikes rolling around with a modern rear hub kit and if I take off the front chain my e bike will look like everyone else who installed a factory kit. That makes my e bike special and if for some strange reason the rear hub fails with a pedal chain and pedal gears I could pedal it fast enough to engage the front chain without it popping off and make it home.
Even though the 1,500W rear motor is a powerhouse and way more power and torque than the 1,000W front chain they can still work together as similar gearing.
Now if you think that 1,500W motor can out perform all my chain drives you will be mistaken. My 1,800W brushless chain drive runs circles over the 1,500W hub. For one thing the torque is ridiculous.. Also when you let off the throttle it is like a Jake brake on a big truck. It slows the e bike down because the magnets in that thing are so powerful.
The seat of the pants instant torque when you press that throttle is addicting. and why it has taken me over two years to even start the 3 kilowatt brushless chain drive. It will take even longer as I decided I will need to run #420 chain and nothing smaller. The motor currently has a 8mm motor sprocket. The 1,800W motor uses #420 chain so am looking for a large #420 or compatible sprocket.
I was thinking about putting the 3,000W motor on the back of the bike with the 1,800W and moving the 1,800W motor up front.
Not that will be a hairy ride.
NO. I am ABSOLUTLLY NOT recommending doing it. I am speaking for myself and everyone else. Right now it is only a pipe dream but I am capable of building such a thing. It will be something out of a MAD MAX movie if I do.
Here is some pictures of my chain drives. All fully functional and many miles on them. The three e bikes are the 36V 1,000W chain on the 20" which is geared for 28 mph and my daily commuter.
The one with the front hub and rear chain is a 750W gear reduction motor rear and 350W front Bafang. The chain geared for 23 mph and Bafang about 21 mph.
The picture of the bike upside down with the inner tube in the box is my 1,800W brushless chain I discussed earlier. 35 mph gearing I think. I clocked it at 32.5 mph at 50V. As soon as I fix the tire it will get 55V - LTO and have my phone now for a GPS speedometer app. The fastest I ever went so far on any e bike is 33.5 mph or 54 kilometers per hour with the 1,500W kit before I installed the front chain above.
I wont be fixing the tire and putting the 3,000W motor on the back but will be riding it as is because if it is not broke do not fix it. That is a heavy duty cargo bike , not a race bike. It has a huge rear cargo basket and also a front basket for hauling stuff.
When I build the 3 kilowatt brushless chain I might order another 1,800W brushless chain for the front so will be a totally different e bike. I will run 20S - 1p 66V HEADWAY cells for 1/2 the weight of 22S - 55V - LTO
3,,000 / 60 = 50 * 66 = 3,300W
1,800 / 48 = 37.5 * 66 = 2,475
3,300 + 2,475 = 5,775W
Gearing = 56 mph.
Skyler.
