speedmd
I thought emissions controls tended to reduce engine efficiency, but maybe they just reduce power.
It is not a simple solution in diesels. They do not run a standard air / fuel ratio like a spark ignition set up. They can run extremely lean. Good for economy, but bad when running hot (Putting the ponies out) as the excess oxygen is key to making NOx. Cooled exhaust gasses can be fed back in, injection pressure increased some, but for anything needing significant power, you need to add fuel without too much O2. These rev high and so the combustion chamber gets hot while making this power so adding any any extra O2 makes large amounts NOx regardless what you do to the fuel supply then. Picture cresting a hill, everything is hot, fuel is cut back but the motor is still pumping air through it.
