I think both batteries are 18650 Li-Ion packs, 48V. The only difference is the Ah capacity. The original one is 14Ah. I'm now thinking of getting a higher capacity battery, 20Ah, maybe even 30Ah to upgrade my e-bike, because where I live there are many hills.Can't tell exactly without the specs of both packs, but if they are made up of the same cells, then the larger pack will be potentially capable of providing more power/current if your controller is capable of handling it.
I hope so. I don't care that my ass hurts. My concern is about controller dysfunction.Using a larger capacity battery should be no problem. You can ride until your butt hurts.
I don’t know how many watts. On Youtube, I saw someone ask how many amps does the Ariel Rider Rideal controller have? A Youtuber answered: 17A.First thing is that you will go about 40% farther with your 20ah battery. So lets say that your 14ah battery could get you 25 miles on a charge, your 20ah battery might get you 34 miles on a charge. Something like that.
The one question is if your battery can handle the amp draw of your controller. How many watts is you controller rated for?
All Ah is is capacity, which makes no difference to the controller, thus no compatibility issues due to an Ah increase.What happens if I use a 48v 20ah battery instead of the 48v 14ah original battery of my ebike?
Is the original controller compatible with a 48v 20ah battery?
BTW, my ebike is Ariel Rider Rideal.
How is your wiring capabilities? An inexpensive watt meter will tell you what your maximum amp draw is when starting from a full stop, or maybe going up a steep hill.
Or, if you don't mind spending a little money a Cycle Analyst will give you a lot more info then volt, amp and watt draw
What is the maker and model of your controller?
Many thanks for letting me know “pack's A rating”. By asking ChatGPT I know that this value describes the maximum current that the battery pack can discharge over a period of time.All Ah is is capacity, which makes no difference to the controller, thus no compatibility issues due to an Ah increase.
The only property that really matters to the controller's ability to handle the battery is the voltage, so as long as it is the same voltage range (empty to full)
Other properties like the pack's A (not Ah, completely different) rating matter for whether the battery can handle the controller and your usage, so you should make sure the new pack's A rating is at least as high as the old one.
