I am building a 15s3p LifePO4 26650 pack.
I wanted to use something better than nickel strip.
The brass shim stock I have is “yellow brass”, I think. Likely not the best conductor but way better than nickel strip. The shim stock is .010” (.254mm) so it should be good.
The trouble is that I cannot get my KWeld to spot weld the brass. Even at 125joules, even when slotting the brass. What I find works well is cutting a window and spot welding a small square of nickel over it, then spot welding that nickel to the battery…..
Is this a sound plan? It seems to be working very well.
I am using 25joules on the 0.15mm nickel, on tests it tears off the battery and leaves a small tab of it on the battery, very similar to the power tool packs I harvested some 18650 cells fromView attachment 1
