Hi
Without doubt the RC approach will be more costly Ypedals experience with his setups ( he is a god person to ask as he has both RC and hub motors) is that in terms of efficiency they run pretty much on a par, to get these RC motors to run at an efficient speed you need high rpms and when you take in to account the losses in the gearing and the belts there is nothing in it, hub motors like the X5 are not very efficient a low RPMs you have to ride with a conservative throttle however most of time you will be running at higher speeds where the motors can run at typically 80% efficiency.
Justin from e-bikes explains this in some detail and it is also my experience from using hub and geared systems, which ever way you look at it you still need x amount of power to run at x speed if you like, I know its not as simple as that but anywhere on any geared system you are going to encounter losses.
The BMC motor is not suitable for off road use I have many of these motors, they are great though for town riding and hill climbing keeping the power below 1200W on these motors really helps with their long term reliability.
And on to reliability, at the moment the RC setups dont appear to be that robust esp when you are comparing them with a direct drive hub motor, a lot of the builds have problems and need bracing, welding and extra bits bolting on, that said they do offer an amazing level of instant power in a tiny unit and I like them very much, I just like relative simplicity of a hubbie, it provides more than enough speed and power for me without any noise or snapping belts and noisy chains.
This bike is almost too good to mess with, the choice is yours of course the RC guys of course favour their setups without often ever trying a fully hopped up X5 I have ridden both and I like them both so wont discount 1 against the other in the same way.
Knoxie
Knoxie
