Nutsert or Rivnut. I'm guessing you stripped the threads on one of the side panel bolt holes.Pop quiz
who knows what this is, and why I need it?
You win Cd, right on both counts, except the threads aren't stripped, the nut spins in the frame. Luckily you can get to the back it from the other side, or it could be a big problem to get the cover off. This one rivnut always has been a little wonky. This is the first time I've ever heard of them. After a crash course on Youtube university last night, now I have a PHD in Rivnut technology, but no actual field experience, yet. I really appreciate Stealth using common fasteners, and bearings when possible, because that makes it s easy to source parts locally.Nutsert or Rivnut. I'm guessing you stripped the threads on one of the side panel bolt holes.
Cheers
Very nice!!!And now let me show you something in white...complete frame off nuts and bolts teardown.
Got battery? Thats a lot of energy storage!Hopefully I get around to making a thread soon of what my bike has turned into and how my 72v63ah battery fits in the frame using 3 sub-packs in series with an external BMS.
I've got a 72v17.5ah pack in a pannier in parallel making the system 72v80.5ah total. Can push 300A peak from the battery and 600 phase amps from the kelly controller.
134km/h top speed.
A few days ago I got an inspection from Washington State Patrol and got a state-assigned VIN, and a license plate.
Insurance from SafeCo ended up being $93/year.View attachment 342295
All my packs are made from Samsung 35E's. I personally would knock them down to like 3.3Ah instead of the mystical 3.5Ah they're perceived to get in ideal conditions, which would get me 5465wh.I could probably get just under a hundred miles on the SB Cruiser trike (about 60wh/mile typical usage) with that much battery (5760wh). (ATM I only have just over a third of that capacity in the old EIG pack, but it's probably less actual usable by now, over a decade into it's lifespan).
What are your packs made from?
Here are a few old pictures when I built the main pack during last winterAny chance we can see how you've fit that inside the frame?
I see how you fit that now....you don't have an actual Stealth Bomber...this is a clone. I was wondering.
That being said, this is still awesome and I would love to have it.
I 'think' I still have the record for largest pack build for a Stealth Bomber/Alpha at 3.25KWh with the 18S14P pack using Sanyo 3.5Ah cells I built back in 2018.
Cheers
what a massive battery, should be good for one trip around the world at least.Here are a few old pictures when I built the main pack during last winter
Was before some various upgrades like the controller swap from KLS7230s to KLS8080h.
Notice how it would be impossible to fit them all in without them being partitioned. You have to get the bottom and top sub-packs in before sliding the middle one in like a jenga piece.
The 180A Cont. ANT BMS sits on the very top (I don't think shown in the picture, was just testing fitment in the picture)
Since you're going to be mainly be riding off road, I would first look for the tires you want to run, and then buy rims that fit those tires. Most of the clones I know of run 18" motorcycle rims.I'm working on setting up a stealth clone and now shopping for front forks. Initial build will be low cost units from china. Wonder what the community here thinks about...
- Air suspension or springs?
- Upside down or not
- 26x4.0 rear tire; 29x4.0 front tire
Riding will be off road below 35 mph. Bike weight under 150lbs (maybe),rider weight 200lbs.
Below is a mockup with a standard MTB front fork with a 26 in front wheel.
