Mikeorrison
- Joined
- Jun 25, 2022
- Messages
- 37
Four wires what are they aside from negative and positive which are obvious how does the 5 volt charge get to the computer from a 36 volt battery with no control box to regulate it
Mikeorrison said:Four wires what are they aside from negative and positive which are obvious how does the 5 volt charge get to the computer from a 36 volt battery with no control box to regulate it
For what specific system?Mikeorrison said:Four wires what are they aside from negative and positive which are obvious how does the 5 volt charge get to the computer from a 36 volt battery with no control box to regulate it
Mikeorrison said:Asif it matters Shimano steps e6000
Mikeorrison said:Play two different I said that's funny two different replies with the exact same word for word it reply anyway Shimano steps E6000 specifically as if it freaking
amberwolf said:...but we'll try anyway...
Hard to believe it's been 6 months already. I swear this year has gone by even faster than the last.Mikeorrison said:Biu a water drop with normal four five lines three lines Asterix I don't know what any of these things are supposed to be for sad for me that I can't communicate to you people cuz I don't know these things mean I don't know what to tell you what somebody can answer my questions about my eBay
the 9 pin connector will be the motor connection 3 x phase wires and 6x sensor, 5v, and gnd wires.. the brown wire?What is the brown wire and the 9 pin connecthey're coming from my KG36/48SVpr-f f F10 l
That would be helpful if it was actually that was the case, this one goes to the to the display or to go to the Hannah bars. Let's go to the motor 19 Gillette 9 pin, that's the problem. Is I ordered one of the Joel that connectors? And it's all different. Everything is condensed there's a brown wire. Come in out of the control box with all the ones that go to the display of stuff. To the 1 the 4 or whatever.the 9 pin connector will be the motor connection 3 x phase wires and 6x sensor, 5v, and gnd wires.. the brown wire?
check this google search for kt pinouts (links back to here a plenty..)
Well, gotta kind of figure out where you want me to reply at 2 different replies. But these things going on it's so confusing.
I bought a Controllbox with jolette connectors. The Wire that goes to display and and all that the one is the 1 to 5 has 9 pins. Doesn't go to the motor there's a S1 on the Circuit board
