casainho
- Joined
- Feb 14, 2011
- Messages
- 6,045
Right, but where can I buy the M510?Waynemarlow said:48 volt is a must ( you can run 52 volt setups ), are you aware that the M500 is no more and its been replaced by the M510 which is lighter and about 10% more powerful ?
Frames, why the Seroxat frame ? the Dengfu frames have now such a wide following + have modern geometries + have so much build advice, that you could save yourself a lot of time and effort in research.
https://www.emtbforums.com/community/forums/diy-ebike-builds.61/
casainho said:Right, but where can I buy the M510?
Seroxat because is aluminium. I am afraid of Dengfu because it is carbon...
I asked Dengfu and greenebikekit and both said they do not sell yet M510.Waynemarlow said:casainho said:Right, but where can I buy the M510?
The M510 looks like its just become available, Melody at Dengfu can arrange the purchase.
Don't be fearful of the carbon frames, they have now been well and truely tested by my fat derriere and a whole lot of others.
https://www.youtube.com/watch?v=RvFD0Q909ZY
Thanks.mirkoser100 said:You can ask cne Bikes on Alibaba. They can arrange the m510. But currently 90days delivery time
Thanks. On my research, I also ended up with only Dengfu E10 frame for M500/M600 motors. Only one option, that is very limited :-( :-(mirkoser100 said:Dengfu e10 from dengfubikes
casainho said:Thanks. On my research, I also ended up with only Dengfu E10 frame for M500/M600 motors. Only one option, that is very limited :-( :-(mirkoser100 said:Dengfu e10 from dengfubikes
Thanks, I did not know yet about LightCarbon frame option.Waynemarlow said:casainho said:Thanks. On my research, I also ended up with only Dengfu E10 frame for M500/M600 motors. Only one option, that is very limited :-( :-(mirkoser100 said:Dengfu e10 from dengfubikes
There are others, LightCarbon, some on AliExpress that are Ali, but mainly hard tails, if you want to go down the development route and I think you have an Ali welder locally ( didn’t you have a cargo bike made ) then you can simply buy an Ali motor mount and weld it into an existing frame. Not a lot of work to do it but you really need to fabricate jigs to ensure the motor sits in correctly to the frame geometries.
But for all the work & cost you will do, a Dengfu E10 or a LightCarbon LC004 will maximise your benefits of the new motor, give you up to date geometries and even a high resale value when you come to move onto the next bike. And most importantly you will be outside riding your bike, enjoying family time more, the quickest.
https://www.emtbforums.com/community/threads/cheeb-v2-build-thread.22529/
https://www.emtbforums.com/community/threads/lightcarbon-lces004-dengfu-e10-alternative-in-usa.21649/
I just need a cheaper option.Waynemarlow said:Expensive mainly because it’s popular, it’s popular because ?
CiDi said:To configure the Bafang M500 / M600 motor without using the BESST programmer, you can use this interface.
Link interface USB to CAN on Amazon:
https://www.amazon.co.uk/USB-Converter-Module-Raspberry-Zero/dp/B07Q812QK8/ref=sr_1_2?dchild=1&keywords=usb+to+can+innomaker&qid=1604409709&sr=8-2
Link cables Bafang HMI M500/M600 on e-bike-technologies:
https://www.e-bike-technologies.de/index.php/en/connectors/connectors-signal/connectors-higo-mini-f-series/higo-b5-f-detail
https://www.e-bike-technologies.de/index.php/en/connectors/connectors-signal/connectors-higo-mini-f-series/higo-s5-f-detail
Below are the software and the instructions for configuration and use.
gm1970 said:CiDi said:To configure the Bafang M500 / M600 motor without using the BESST programmer, you can use this interface.
Hi CiDi, i have read your post regarding the CAN convertor to configure Bafang M500 without BESST programmer. It seems interesting but i have a few questions.
- How do you distinguish the different frame id's (setup, torque sensor calibration, Position sensor calibration)?
- Can you change the torque settings and if so, how do you do that?
I have a M400 and i want to change the torque settings if possible.
I found the carbonbikekits frame, that I would save about 200€ compared to the Dengfu E10. But I can not found any review or how to build an ebike with this frame - does anyone know a link for such information??Waynemarlow said:Make your own battery, Bafang supply a motor connecting lead with the kit, that will save you 300,
https://www.emtbforums.com/community/threads/can-you-build-your-own-battery-for-the-e10.19530/
Use a lot of your own existing components from your old bike, last years XT is this years Deore and we all thought last years XT was top class. Be thankful of those who do more polishing than riding, they do tend to want the latest and greatest and EBay and the likes always seem to have their cast offs up for sale.
Animalector said:Has anyone described the process to actually calibrate the torque sensor (like hang a 1kg mass from the pedal?)
So it is probably just for system to record the offset value it has as 0kg force.CiDi said:Animalector said:Has anyone described the process to actually calibrate the torque sensor (like hang a 1kg mass from the pedal?)
The torque sensor calibration must be done empty, without any weight.
casainho said:So it is probably just for system to record the offset value it has as 0kg force.CiDi said:Animalector said:Has anyone described the process to actually calibrate the torque sensor (like hang a 1kg mass from the pedal?)
