windburner said:
I think that reversing a version is very important ...
Looks like my "reversing a version via bluetooth" comment was very much appropriate, as I'll need to do a bit of soldering to revert to 0.19.11 for tomorrow morning's ride (or revert to the TSDZ2 factory firmware and to the VLCD6 display and wait for the next SW102 update).
The update via bluetooth from .11 to .15 went very easy. However, with 0.19.15, using UP+DOWN to go between screens, the sequence for my unit is, main screen, info screen, settings screen, to OFF!!! Just in case, I waited for some time (up to 180 seconds) to see if it would reboot and return with a fault code, but it remained off. In fact, I got to a black screen in many ways, without touching the power button.
The reason I need to revert is the fact that, no matter what I did, no setting changes were ever saved, thus, it can't be configured for my trike and ride profile, and the default settings will not work.
Also, I experimented with the ability to change the info screen configuration, which is a nice feature, and these too could not be saved.
Will attempt to report an issue, which could be a large report if I tried to report everything encountered.
On the positive side, I do see lots of promise with these changes.
