rowan
- Joined
- Apr 12, 2020
- Messages
- 16
I’ve had this one hanging around for about 21 years, and for a decent amount of that I wasn’t in a place where I either needed to or (later) could easily use it regularly. But I figured the time has come to put a motor on it and use it for some local grocery hauling.
Basic BikeE CT, no suspension. Purchased new in the late 90’s in Madison, and seen pretty light use since then. I’ve added an Axiom rack to the back, so with the under seat racks I can carry 4 panniers. And then I built a nice wood crate to go on top of the rack. It’s ready for my weekly grocery run.
I live in the East Bay area (Oakland), and there are a few hills, but a lot of my life revolves within 5 miles of the house. I like the 21 speeds in this as it is, so either a mid drive or a front hub was going to be the answer. I decided on a front hub to start with, and we’ll see how it goes - I don’t mind earning my miles with a little leg sweat. This is Grin’s Bafang G311 ready to ride kit laced into a 16 inch wheel. Original wheel for reference:
The ready to ride kit comes with a CA3-WP.
I got the e-brake levers, and yanno, there’s not a lot of space on these little handlebars. There’s a Problem Solvers extension bar for the Cycle Analyst, and that leaves just enough space for the shifters, throttle, aux buttons, bell, and Garmin Edge 130 mount.
I got a basic DC front headlight, and not pictured is a rear light. I’ll need to enlarge an already present drain hole at the front of the frame to run the DC extension cord to the rear, but that shouldn’t be too hard.
Basic PAS sensor is basic, not pictured, and should be fine. The other frame adjustment I’ll need to make is the front fork. After putting on the wheel, something was rubbing. I figured I’d let it go while I put everything else together, but after a test ride I found it. The bolts holding the motor cover on rub just a touch against the inside of the fork. A little filing on the fork should fix this.
The last piece, and arguably one of the most important, is the battery and Baserunner controller. UPS and customs are still sitting on it, so it’ll get here later this week. I’m probably going to mount it in the frame right in front of the seat, but we’ll see where it fits best.
I’ve got some Ergon grips coming from the bike shop half a mile away, and I’m going to use a rear wheel stand for a kickstand. Expect an update in a few days for how this is coming together.
