speedyebikenoob
- Joined
- Feb 6, 2019
- Messages
- 333
fatty said:It wouldn't. Torque is a function of torque constant (Kt) in Nm/A, amps, and gearing.speedyebikenoob said:If I use the same power motor controller on the cyclone 3000 as I did on the mini, and I gear it to have the same top speed in each gear as my mini, why would the cyclone 3000 have more torque? Where does that extra torque even come from?
The Mini is geared with 9.55:1 primary torque multiplication, whereas the 3000 is geared with 6:1 primary torque multiplication, but the 3000 probably has higher Kt to compensate. So if you use the same controller with the same amps, it wouldn't have more torque -- they would be about the same.
The advantage to the 3000 (as with all larger motors) is that it can take more amps, and for longer, and thus make more torque (and thus power):
Okay this makes perfect sense thank you I'm guessing I should expect a small power increase though with a larger motor because it'll be more efficient than the lesser motor right? Less power goes to heat and instead into the wheel where it's supposed to go? Probably a small difference though.
