Golfer-Electric
- Joined
- Mar 22, 2021
- Messages
- 17
Why are the new batteries so much smaller? Is it cell quality? The original battery is a huge beast. It doesn’t have cylinders. It is like pouches put together
Golfer-Electric said:Those are same grips I put on my wife’s specialized which I built with a Bafang BBS02 motor. I just thought since it’s twist throttle you wouldn’t want that shape for twist. Very comfortable grip. Especially downhill
Golfer-Electric said:Why are the new batteries so much smaller? Is it cell quality? The original battery is a huge beast. It doesn’t have cylinders. It is like pouches put together
Allex said:Got a Kelly KLS7218S installed
Gives me over 100A battery amps and over 200A phase amps to motor with a 35mm wide stator. 5403 on bombers are 43mm (or 42mm) Wider stator gives you more torque.
https://www.qsmotor.com/product/kelly-controller-kls7218s/
My old bomber got over 400A phase amps to motor, but you have to have a temp sensor installed to monitor the temp.
If you can get a nucular 12F or 24f - do it! it is a fantastic piece of hardware with great support. Otherwise, kelly is fine But it is a bit of a hassle to connect it to the CA and you need to program it using a PC, did not get it to work with their phone app.
https://www.aliexpress.com/item/32811686999.html controller drawing1abv said:Allex said:Got a Kelly KLS7218S installed
Allex,
The Kelly KLS7218S. Do you happen to know the dimensions?
The overall frame with of the bomber is 106.37mm and the width between the side panels is 133.35mm. When I looked at the Sabvoton its 146 wide but seems like some people have figured out a way to trim the side tabs and get it to fit.. Wanted to see if the kelly was the same.
BTW I for in touch w stealth and they want $585.00 usd for a new Crystalyte 65a controller.. yea...
Allex,
cheeko said:I have the 12F Nucular on my Beta Frame its tiny and have had it since release so about 2 years now, Best controller screen is unreal like adapatto but much more features and everything is changable in screen.
12F was enough for me and its tiny and will highly recommend it over any other controller i have had, I used Powervelocity and its much more controllable for throttle
I'm running 105amp battery with Mxus3k and its rock solid
1abv said:So if im reading this correctly im on the edge of the 12F and 24F nuke...Is that correct?
My Battery:
Max-160
Continuous-80
Nuke 12:
Battery max~150
Nominal power 5 000W (80V+)
TV yup..... If I can't get my controller up and running again then off to get the kelly. Where are you finding them? Alibaba?
1abv said:https://endless-sphere.com/forums/viewtopic.php?f=2&t=35278&hilit=phase+current
Take a look at this link.. ive been reading it to bone up on phase current... starting to get it...still confusing
Did u get ur math wrong cuz 25 x 90% is like 22.75... I’m too lazy for a calculator righ5 now, plus I can’t type so... lol1abv said:I found this regarding Phase amps... Does this seem correct?
The term battery current can refer to several different things:
Actual battery current - the current you will see in an ampermeter connected to the battery at a given moment when riding.
Rated peak battery current - the maximal current the manufacturer claims that will not instantly fry the hardware.
Rated continuous battery current - the maximal current the manufacturer claims that will not fry the hardware when applied for an extended period.
Battery current limit - the maximal current the controller is allowed to draw from the battery.
The same terms apply for phase current (simply replace "battery" with "motor").
The actual battery current and actual phase current are constantly changing according to riding conditions.
The relationship between actual battery current and actual phase current is not fixed, it is also constantly changing according to riding conditions.
A simplified explanation for the relationship is: Actual battery current = actual phase current X %PWM .
The PWM is effected by motor speed, throttle position and load on the motor.
When at low speeds/high loads/a lot of throttle, the phase current will be much higher than the battery current and when cruising at high speed they will be very close.
If either battery or phase currents exceeds the maximum set in the controller it will reduce current draw accordingly.
For example:
Suppose the controller is set to limit the phase current to to 50 Amps and the battery current to 25 Amps.
If you are running at 25% PWM and the motor is drawing 40 Amps, the actual battery current will be 40 X 25%=10 Amps. No limiting is in effect.
Then a you start climbing a hill. Still running at 25% PWM, the motor now needs to draw 60 Amps. The phase current will be limited 50 amps and the battery current will be 50 X 25% =12.5 Amps.
After the hill you ride at high speed, say %90 PWM. The motor needs 45 Amps which means that the controller will need to draw 45 X %90 = 40.5 Amps from the battery. Since it is limited to draw only 25 battery Amps, the actual phase current will be 28 Amps (25 X %90 = 28).
