Hillhater
100 TW
…..and dont forget the inclines . Even a steady speed up a hill will soak up more power than aero !Depends on how much/how frequent the stop and go is.…..
And downhill aero losses are offset by gravity assistance .
The power you gain is also not only from the loss of mass, but the consequence of having less rotational inertia allowing the engine to potentially spin to a higher RPM and thus, make more power- Mitsubishi 4G63's are proof of that, though with them it's a balance shaft and not counterweights directly on the crank itself. Old V6'es too (like Fords, I think the Vulcan is counterweighted). Since it's a bottom-end OUT and machine shop alteration tho, it's nothing that receives similar attentions to piston and rod weight or other things that also reduce rotating mass so I can't point to studies in-vacuum.JackFlorey said:Counterweights don't use "tens of horsepower." They use zero. The only time you notice them is during acceleration, when you have more engine mass to accelerate. This energy is returned when you decelerate.
CONSIDERABLE SHOUTING said:Which also makes me ask, what kit cars are built not only for track days but also are built for high-aero; I know from Grassroots Motorsports that the Locost's biggest weakness is it's Cd is ~0.42 and I think most Platovs are too expensive for most to get (Except MAYBE the D4). You could likely form and shape a new body for a Locost, but you will have problems moving the rear wheels "in" and expanding the front track as that'll change it's entire suspension dynamic.
God, long shot here but... the 80s Dodge Wraith, didn't that get a kit car form from the fans? I know that stock had a Cd of like, 0.21.
Well, _most_ of it is recovered - and "coasting to a stop" is still using regen. But I do use neutral quite a bit in my EV, simply because it's more efficient to store potential energy in speed than via regen.ZeroEm said:Even in my EV, try to coast to a stop, try not to use regen unless going to fast because that is a waste of energy too.
Agreed there. Counterweights place limitations on engine speed and acceleration that can limit power - although that's different than efficiency.CONSIDERABLE SHOUTING said:The power you gain is also not only from the loss of mass, but the consequence of having less rotational inertia allowing the engine to potentially spin to a higher RPM and thus, make more power
I saw it in a youtube video that I can find later and post about movie cars; they really should have, because it was the last of the PACE cars and ended up inspiring the Viper released 4 years later. It also used essentially, the same underpinnings as the Plymouth Horizon/Dodge Omni and could have competed well against the MR2 and the Fiero if they could get the cost down.The Toecutter said:I'm not aware of a kit build of this concept. That car could get 40 mpg on the highway, even though it made somewhere around 400 horsepower. Dodge could totally have sold something like that in the early 1980s, when the average car was getting somewhere in the 1X mpg range and had anemic acceleration.
Hillhater said:…..and dont forget the inclines . Even a steady speed up a hill will soak up more power than aero !
CONSIDERABLE SHOUTING said:That Eleven is pretty neat; wonder what it's engine bay looks like cause it's STUPID low.
Problem I see tho- we have to keep any kit or idea as reasonably accessible as possible. The Locost achieves that through literally having a racing chassis people have built for a few hundred bucks; gotta have that kind of saturation, and the ability to use common EV drivetrains like Tesla S and Leaf units.
Also, the Wraith looks rad as hell. 80s Aesthetic that could be massaged in a few small ways, a coupe that still has internal space and stowage. Seeing images from the movie it also has a high center tunnel and plenty of rear engine bay space, so arguably it'll have no problems taking a wide range of engines (and possibly even having rear 2+2 seating). The video had some dude that apparently found the OG molds to make his own; If I was gonna make a kit car, I'd make THAT one.
I forgot that was also 80s dodge, so another reason they didn't make it production-scale is because they nearly bit the bullet literally 8-10 years prior and genuinely only made the Viper because it was SO wild for the era :lol: The history of the Dodge Aspen is... amazing.The Toecutter said:That would make a great EV platform, IMO. A 2,500 lb EV with a 400 lb battery pack and about 300 horsepower could be the ticket to an affordable $25-30k 300+ mile range sports car that can accelerate like cars 10x the cost and out corner them by virtue of being light and balanced. With such a low drag and weight, 150 Wh/mi would be a very realistic and achievable goal.
CONSIDERABLE SHOUTING said:As for Mazda, they can't do that without altering the length of the wheelbase which also affects suspension design. Short suspension means smaller turning radius; the current ND still gets 36MPG for the EPA so 40 is doable on highway, I'd still take that.
by JackFlorey » Jul 03 2022 10:52am
Well, _most_ of it is recovered - and "coasting to a stop" is still using regen. But I do use neutral quite a bit in my EV, simply because it's more efficient to store potential energy in speed than via regen.ZeroEm wrote: ↑Jul 03 2022 5:55am
Damn thing paywalled me after one article. And they wonder why people fall for conspiracy websites all the time? It's cause they can actually read the damn things.The Toecutter said:Old article, but even more relevant today now that gas prices are high:
https://dailycaller.com/2019/09/03/cities-towns-landscape-despair/
This landscape described in the above article is rapidly transitioning from "barely livable" to "unlivable" for all but the wealthy.
Ianhill said:i suppose the pain russia will feel from war won't be in oil prices or not as the war effort happens if they/putin can help it.
Chalo said:A dictator can artificially suppress gasoline prices, right up until he can't.
Chalo said:Ianhill said:i suppose the pain russia will feel from war won't be in oil prices or not as the war effort happens if they/putin can help it.
goatman said:Chalo said:Ianhill said:i suppose the pain russia will feel from war won't be in oil prices or not as the war effort happens if they/putin can help it.
that is funny as frock coming from an American Democrat
Unless you can produce some convincing cost data to back up that statement from “multiple sources”…. I call Bull 5hit on that !The Toecutter said:The U.S. corporate dictatorship has been doing it for decades. Oil and oil-derived fuels are subsidized orders of magnitude more than any renewable energy is. The entire world has been artificially suppressing the price of gasoline, for that matter, by ignoring externalities associated with its production, storage, transportation, and use. Were externalities accounted for, gasoline would be well over $10/gallon according to multiple studies out there…..
Hillhater said:Unless you can produce some convincing cost data to back up that statement from “multiple sources”…. I call Bull 5hit on that !
Where do youthink all the multi Trillions of petro dollars stashed away by oil companies comes from ?
.. Who do you believe could provide a subsidy of $5-$8 per gallon for every gallon sold ?
..why would a product based on free base material , refined in massive quantities, have a “value” of $10+ ?
THE EXTERNAL AND SOCIAL COST OF GASOLINE
Low estimate: $4.60/gallon or $558.7 billion/year
High estimate: $14.14/gallon or $1,690.1 billion/year
Estimate assuming oil price spike and new tax subsidies:
$14.37/gallon or $1,718.9 billion/year
THE REAL PRICE OF GASOLINE125
Low estimate: $5.60/gallon
High estimate: $15.14/gallon
W/price spike: $15.37/gallon
You need to rethink your predudices !, and get a sence of perspective
Without the energy provided from oil and coal,.. you , I, your velomobile,.. and the entire civilised society we enjoy,..would not exist ,!
