dequinox
Oh I plan to get a little use out of them at least after all that work! I knew it would be an uphill climb putting that all back together, but it was worth the learning alone. I hadn't ever worked with pouch cells before, so it was a good experience at least. I still have the other battery to go through too!
I will check the charger's output voltage... it should be about 57.6V is that correct? 3.6v per cell?
Rassy said:Sounds promising. I have had chargers that have their total voltage output drop a little, ... I hope you get some good use out of those old cells after all the work you did to get to this point.
