barneys34 said:
i have had a 500 watt cyclone kit for 2 months with high power psi lifepo4 24 volt battery its good for around 22 mph and can climb hills because it uses my bikes gears i wanted some thing a bit better so i purchased a heinzman kit with a nimh 9.5 amh battery and 2 motors a high torq hill climbing motor {16 mph} works great but not want i want i was looking forward to fitting the high speed low torq motor but i was very disapointed to say the least the motor will not pull the bike if there is a slight head wind or if u are below 15 mph i am looking for information from u guys on what the problem could be the high torq motor works as it should so the battery and 30 amp speed controller are ok i am thinking of selling the heinzman motors and speed controller and buying a nine continents kit for ebikes.ca i will keep my 36 volt nimh{saft} battery and i also have a new ping 48 volt 10 amp lifepo4 battery that should get me between 25 and 30 mph with the nine continents kit
Just some personal opinions;
Yes, most hub motors will have trouble matching the same hill climbing and top speed specs as a cyclone with the same batteries.
but If you are only getting 22mph out of a 500w cyclone with a good set of high power psi lifepo4 cells, you might have a bike problem. I get that out of a 360w cyclone with 2 yr old Nimh.
I would wonder what your rear cluster might be. If you run a 9 speed 32/11 on a 26" wheel, you should see some real good hill climbing and about 26mph.
Another problem you may be having is the H'mann wants a lot of current. LOTS at startup and under load. Put a meter on that Nimh pack and see what kind of sag you are getting.
Plus-- one rides. shifts and pedals a chain drive differently than a hub motor --as the multipliers are different, as is the attempt to stay on the motors sweet spot for hill climbing. On a chain drive one maintains motor speed by shifting the chain, lower bike speed is OK. On a hub motor one maintains motor speed by keeping the bike going fast and avoiding drops in bike speed.
On my cyclone I can recover from dropping to 5mph up a hill, but on the Bionx cannot let that happen.
anyway, that is my 2 watts worth.
d
