I have tried to find a replacement controller with no luck. Does anyone know where i can find a compatible controller? It controls my XOFO 750w Motor on 20" Fat wheels. My battery is a 48v
How exactly were you wiring the lights? NOrmally those get connected to the battery or a DC-DC, not the controller. So if that's the case, it' more likely your battery that has a problem (BMS, fuse,e tc) than the controller.amug1 said:Like a dummy….I installed a aftermarket headlight and brake light….and forgot power was still on and….bzzzz! DOH! Now neither work
amug1 said:Lights are definitely connected to the actual controller. I'll open the controller up to investigate. Not really sure on HOW to use my volt meter on it though. I'm learning as I go....Thx
amug1 said:my index finger is touching both the headlight and tail/brake light connections going to the controller.
amug1 said:I tested the new light and.....Shorted it out which caused the taillight to not work properly (very dim)....same goes for the headlight. UGH so frustrating and the bike mfg want $120 for a replacement controller (just found out today they do have them).
E-HP said:amug1 said:I tested the new light and.....Shorted it out which caused the taillight to not work properly (very dim)....same goes for the headlight. UGH so frustrating and the bike mfg want $120 for a replacement controller (just found out today they do have them).
So is it that the lights aren't working, but the controller is, or the controller no longer powers the bike? I'd odd that the lights still work, but dimly. Are you sure the new lights are the same voltage as the old ones? I assume the old lights no longer work when plugged in.
amug1 said:The Bike motor works and rides perfect...I just shorted the lighting system. Both headlight and brake light were working until the SHORT happened. Its like I freaked out the controller internally.
fechter said:Do you know what voltage the lights run off?
